leet5r Posted March 23, 2010 Report Share Posted March 23, 2010 hi guys am new to this site. well am from england and over here we only have the 16,18 and 19t which is a direct bolt on , i have a manual saloon t5r in olive green that needs more power , i have seen a few post of poeple with a 20g . i had a quick look to see what these were and there off the td05 and td06 series turbo , what is involed with this sort of upgrade. cheers and how do you read messages that you have already read , thanks guys Link to comment Share on other sites More sharing options...
lookforjoe Posted March 23, 2010 Report Share Posted March 23, 2010 This my HRC 20g Install Thread. Since you're FWD, it'll be somewhat easier to deal with the plumbing. I fabricated steel oil/water lines, some use flexible line w/AN fittings. clock the compressor housing, & retap for the actuator.. You'll have to fabricate a custom DP, of course. Get TurboTuner for the tune. You won't find an off-the-shelf tune that will work properly. Link to comment Share on other sites More sharing options...
greekone Posted March 23, 2010 Report Share Posted March 23, 2010 If you decide a 20G is for you, I have one for sale. Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 If you decide a 20G is for you, I have one for sale. hello m8 am in the uk so it could be a prob i also have a 50trim t3t4e aswell which i have been advised not to use Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 This my HRC 20g Install Thread. Since you're FWD, it'll be somewhat easier to deal with the plumbing. I fabricated steel oil/water lines, some use flexible line w/AN fittings. clock the compressor housing, & retap for the actuator.. You'll have to fabricate a custom DP, of course. Get TurboTuner for the tune. You won't find an off-the-shelf tune that will work properly. how much power are you running with that, and whats the lag like ,and could i change the exhaust housin so i could run a 3inch down pipe Link to comment Share on other sites More sharing options...
EricF Posted March 23, 2010 Report Share Posted March 23, 2010 i also have a 50trim t3t4e aswell which i have been advised not to use Who advised you of this? That turbo is along the lines of a TD05H-20G.. What are your goals for the car? Powerband in terms of RPM, horsepower? I think if you have that turbo already, you'd be crazy to try to replace it with a 20G. Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 Who advised you of this? That turbo is along the lines of a TD05H-20G.. What are your goals for the car? Powerband in terms of RPM, horsepower? I think if you have that turbo already, you'd be crazy to try to replace it with a 20G. just some lads on the english forums m8 , i want as much power as i can get really , i know i will need a diff and brakes etc to cope with the power. the turbo is .50 on the compressor and .63 on the exhaust side , i dont know much about turbos and was wantin to run it with external waste gate chhers Link to comment Share on other sites More sharing options...
TorqueSteer Posted March 23, 2010 Report Share Posted March 23, 2010 could i change the exhaust housin so i could run a 3inch down pipe You can run a 3" downpipe, but you will have to make a slight adaptor. The turbo makes plenty of power as it is, even with that exhaust restriction. Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 am new to this site and have just put a few pics up of my car and the t3t4 turbo lol , am haven trouble messengen people like Link to comment Share on other sites More sharing options...
lookforjoe Posted March 23, 2010 Report Share Posted March 23, 2010 how much power are you running with that, and whats the lag like ,and could i change the exhaust housin so i could run a 3inch down pipe I'm working on getting over AWD 300WHP - recent dyno was only AWD 260WHP - the tune is key (homemade) 3" DP just some lads on the english forums m8 , i want as much power as i can get really , i know i will need a diff and brakes etc to cope with the power. the turbo is .50 on the compressor and .63 on the exhaust side , i dont know much about turbos and was wantin to run it with external waste gate chhers Also curious to know what the rationale for NOT using that turbo was.... Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 I'm working on getting over AWD 300WHP - recent dyno was only AWD 260WHP - the tune is key (homemade) 3" DP Also curious to know what the rationale for NOT using that turbo was.... every said its not a good turbo and wount fit , not sure apart from that m8 Link to comment Share on other sites More sharing options...
BlackT5 Posted March 23, 2010 Report Share Posted March 23, 2010 every said its not a good turbo and wount fit , not sure apart from that m8 It will fit no problem, just have to machine the manifold flange flat. It looks to be a T3 turbine? How much HP are you aiming for? Is your motor built or still stock? Link to comment Share on other sites More sharing options...
leet5r Posted March 23, 2010 Author Report Share Posted March 23, 2010 its defo not goin on a stock block lol , am busy rebuildin 1 at the min , well i havent started , i need to get some rods and pistons. i want as much power as possible , i got the turbo for free so thats why am tryin to fit it in lol., i want the car to responsive aswell Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted March 23, 2010 Report Share Posted March 23, 2010 Mind linking us back to your topic on the English forum? Link to comment Share on other sites More sharing options...
impulse922 Posted March 23, 2010 Report Share Posted March 23, 2010 just some lads on the english forums m8 , i want as much power as i can get really , i know i will need a diff and brakes etc to cope with the power. the turbo is .50 on the compressor and .63 on the exhaust side , i dont know much about turbos and was wantin to run it with external waste gate chhers the external gate part might be a problem :unsure: Link to comment Share on other sites More sharing options...
