What'S The Weakest Link?
washdup
Hmm, weird. Sounds like the problem is the wiring harness between the amp and the HU. You said it was integrated into the amp?
Should still rule out a possible wiring issue as suggested.
  • Replies 48
How?
Either use a multi-meter and test for continuity or with a small lead, wire the tweeter directly to the supposedly bad amp channel. If it plays you know your answer. If the clip leads on your meter are removable, you could use those instead of wire.
Thanks mk. For now, first step is I'm going to check the EQ settings and enjoy it even with the crippled amp. Then I'll have to decide whether the bass is sufficient as is, and if not, decide whether the existing speakers would be enough with a 100 x 4 Volvo amp, or whether to go with a different amp with 5 channels and some kind of sub setup. The latter option gives me some pause because there are so many choices about amps and subs and mounting locations, and then all the wiring, etc. Probably not that big a deal, but it's a new area for me and giving me some hesitation.
