S8ET6 Posted April 3, 2010 Report Share Posted April 3, 2010 I'm not getting more than 10lbs of boost until I am above 4000 rpm. While data logging, I noticed that my AFRs are a constant 14.7 - regardless of throttle position. I don't have any codes Is this a sign of a bad ETM, or something else. Link to comment Share on other sites More sharing options...
loseR99 Posted April 3, 2010 Report Share Posted April 3, 2010 I'm not getting more than 10lbs of boost until I am above 4000 rpm. While data logging, I noticed that my AFRs are a constant 14.7 - regardless of throttle position. I don't have any codes Is this a sign of a bad ETM, or something else. Possibly a vac/boost leak? Have you checked intercooler pipes and vacuum lines? Or possibly CBV leak or wastegate. If it's not getting the boost until that late it will stay close to 14.7 at all cost. Fix your boost issue and it will give you the fuel. Link to comment Share on other sites More sharing options...
