Fitzy Posted April 5, 2010 Report Share Posted April 5, 2010 So this is probably a n00blet question but what exactly is the application difference between these 2 sets of calipers? Obviously 1 is meant for awd and the other fwd based on the description, but if the mounting points are the same, and they use the same size rotors then whats the deal? Clearance? IPD also does not offer AWD rear calipers if you buy parts based on their description. FWD AWD This is for a 98 V70R. Also, called tech services at FCP and he mentioned the mounting is the same bracket but that I cannot use FWD with AWD. Note: I did order the wrong set of calipers... :( Link to comment Share on other sites More sharing options...
Oreo931 Posted April 5, 2010 Report Share Posted April 5, 2010 The calipers are very different. I'm not positive if you can swap them, but I know for a fact they are different. Link to comment Share on other sites More sharing options...
sconeman Posted April 5, 2010 Report Share Posted April 5, 2010 The calipers are very different. I'm not positive if you can swap them, but I know for a fact they are different. the FWD are two piston the AWD are single piston. Also the rotors are different and in a different position on the AWD etc etc. Link to comment Share on other sites More sharing options...
