Freshbread Posted April 6, 2010 Report Share Posted April 6, 2010 I can't seem to confirm what head unit this will work with...it says it is a PIE OEM adapter. I have a sc-810 with factory cd changer wiring to the rear of the wagon. Just want to make sure before I start locating a wiring diagram for install. What do you gus think? Link to comment Share on other sites More sharing options...
echo5625 Posted April 6, 2010 Report Share Posted April 6, 2010 that is the alpine connector looks like the vola2, should work with any factory hu with changer controls, all you have to do is power those 2 wires and it should install fine. connect(yellow wire) to Permanent 12v supply and connect (red wire) to Accessory/Switched 12v supply. Link to comment Share on other sites More sharing options...
Freshbread Posted April 6, 2010 Author Report Share Posted April 6, 2010 that is the alpine connector looks like the vola2, should work with any factory hu with changer controls, all you have to do is power those 2 wires and it should install fine. connect(yellow wire) to Permanent 12v supply and connect (red wire) to Accessory/Switched 12v supply. Thank you :excl: Link to comment Share on other sites More sharing options...
