Fake-R Posted April 8, 2010 Report Share Posted April 8, 2010 I'd like to take out the center "support" bar from the front of my car, behind the grille. The one right under the hood release. I'm just wondering if anyone has done it, and if the structure held together without that bar in place. (Thanks to Zaitz for the picture) Link to comment Share on other sites More sharing options...
Mesoam Posted April 8, 2010 Report Share Posted April 8, 2010 yes i've seen a number of 850's with that piece removed, the header panel holds up fine Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted April 8, 2010 Report Share Posted April 8, 2010 Pretty sure some high power swedes have done it, And I think there was a guy in Australia with a massive front mount that he stuck right about there. Link to comment Share on other sites More sharing options...
volvo500bhp Posted April 8, 2010 Report Share Posted April 8, 2010 Its not a problem it works for me and still has plenty of strength : Russ Link to comment Share on other sites More sharing options...
Alan M Posted April 8, 2010 Report Share Posted April 8, 2010 It does weaken the structure quite a bit in the 850 and make it fairly flimsy. 70 series plastics are more rigid in that area and fair better with the centre upright removed. Link to comment Share on other sites More sharing options...
lookforjoe Posted April 9, 2010 Report Share Posted April 9, 2010 I would agree that it will weaken the panel, especially if you're still using the stock hood safety catch. Russ - doesn't your car have side pins through the hood? If so, in your case, removing the center bar is a non-issue. Link to comment Share on other sites More sharing options...
volvo500bhp Posted April 9, 2010 Report Share Posted April 9, 2010 I would agree that it will weaken the panel, especially if you're still using the stock hood safety catch. Russ - doesn't your car have side pins through the hood? If so, in your case, removing the center bar is a non-issue. It does not weaken the panel that much the standard centre catch would work fine without it i only removed mine because the intercooler is pushed right forward, i like the Aerocatchs :) Link to comment Share on other sites More sharing options...
laird Posted April 9, 2010 Report Share Posted April 9, 2010 It does weaken the structure quite a bit in the 850 and make it fairly flimsy. 70 series plastics are more rigid in that area and fair better with the centre upright removed. I'm not sure what your looking at there. I'd say just the opposite looking at them side by side. The hood latches are at each side, attached to metal work, and the center latch only holds the secondary. Link to comment Share on other sites More sharing options...
Kevin. Posted April 9, 2010 Report Share Posted April 9, 2010 I might do this just to clean up the looks of my front end..... I'm liking how it looks. I'm just assuming that you would use a saw and cut that business out of there Link to comment Share on other sites More sharing options...
Alan M Posted April 9, 2010 Report Share Posted April 9, 2010 I'm only going by what I have seen as I thought about this mod myself as I have a very large frount mount but going by what cut 850 plastic I saw I decided not to. Link to comment Share on other sites More sharing options...
bum2kev Posted April 9, 2010 Report Share Posted April 9, 2010 its a non issue anyway. its very solid even when you remove it as the whole core rad,ic,ac bolts to the frame and the core support. also take the lower part out as it wont be doing aything other than blocking the ic. Link to comment Share on other sites More sharing options...
Falcone Posted April 9, 2010 Report Share Posted April 9, 2010 +1 to hanks. I cut mine a long time ago, and I stand on it when I swap summer/winter hoods, and it doesn't flex. I've even jumped on it for fun. Link to comment Share on other sites More sharing options...
lookforjoe Posted April 9, 2010 Report Share Posted April 9, 2010 The thing is, it isn't going to make any difference to cooling (I've tried running w & w/o front bumper over the FMIC, and that made 0 difference to recorded temps), so I guess if you consider it as a purely cosmetic mod that reduces the front end safety structure in the event of an accident, then it's all good :lol: Link to comment Share on other sites More sharing options...
bum2kev Posted April 9, 2010 Report Share Posted April 9, 2010 that part has nothing really to do with crash safty. its fiber infused plastic. you could break it by kicking it. Link to comment Share on other sites More sharing options...
lookforjoe Posted April 9, 2010 Report Share Posted April 9, 2010 that part has nothing really to do with crash safty. its fiber infused plastic. you could break it by kicking it. That may be so, but every panel is designed to absorb impact, progressively, depending on severity of collision. Volvo doesn't arbitrarily add unnecessary material. Not that it really matters, if your car was hit over the bumper hard enough to push in the fenders/rails. etc., you'd probably scrap it anyway. :D Link to comment Share on other sites More sharing options...
