mulcy Posted April 11, 2010 Report Share Posted April 11, 2010 This was my first time pulling an engine. I went at it alone with the Haynes manual and, except for 2 or 3 broken clips and hoses, it was a surprisingly smooth job. The hardest parts were detaching the hydraulic mount by the firewall (I couldn't get my socket to stay on either the upper or lower bolt, so after a lot of swearing I ended up just detaching the bracket from the engine) and undoing the ground for the engine harness by the passenger side headlight. Now that it's out, what should I put back in? Should I stick with a 98 2.3 or would it be safe to go with a 2.4 (plus my t5m ecu) for a little performance bump? Any input on using an engine from a different year? I've heard that a 99+ would be hard, how about an engine from a 96 or 97 850t5 or R? Also, I'm just starting to put together my list of parts to change while I have the chance. So far: -rear main seal -cam seals -clutch -pcv -timing belt/tensioner/waterpump was done 1.5 years, 20,000 miles ago so I'm contemplating just switching it over -front and rear hydraulic engine mounts -maybe subframe bushings? Any additional suggestions? Link to comment Share on other sites More sharing options...
Chilled man Posted April 11, 2010 Report Share Posted April 11, 2010 04 R motor :lol: Link to comment Share on other sites More sharing options...
mulcy Posted April 12, 2010 Author Report Share Posted April 12, 2010 04 R motor Anyone ever done that? V&S has one with 29000 miles for 2800... There's also a junkyard in canada that's listing one with 56k for $740. Too good to be true?! Link to comment Share on other sites More sharing options...
Chilled man Posted April 12, 2010 Report Share Posted April 12, 2010 Anyone ever done that? V&S has one with 29000 miles for 2800... There's also a junkyard in canada that's listing one with 56k for $740. Too good to be true?! I am and that second one sounds way to good to be true Link to comment Share on other sites More sharing options...
