Marc91988 Posted April 18, 2010 Report Share Posted April 18, 2010 Tried doing a search but haven't come across much but the SC901 in my c70 just shuffles through cds and doesn't play them (no there not burned) is this usually the cartridge or the deck. would like to have some music while i save for a deck. Thanks ! Link to comment Share on other sites More sharing options...
mkc70 Posted April 18, 2010 Report Share Posted April 18, 2010 Tried doing a search but haven't come across much but the SC901 in my c70 just shuffles through cds and doesn't play them (no there not burned) is this usually the cartridge or the deck. would like to have some music while i save for a deck. Thanks ! You could try running a CD lens cleaner first. If you are more capable then open it up and take a look around. One possible fault listed is a ribbon cable that moves with the cartridge that can sometimes slip out of position. I have one that just shuffles as well, but I believe it needs the laser replacement(just lazy and do not use CD's). Can also buy a 6 disc changer to play cd's that plugs in the back. Link to comment Share on other sites More sharing options...
revolvolution09 Posted April 18, 2010 Report Share Posted April 18, 2010 Sounds like laser not reading 'em. Link to comment Share on other sites More sharing options...
SlapShot Posted April 19, 2010 Report Share Posted April 19, 2010 So the vast majority of the 901s that wont read discs might be because a ribbon cable is disconnected or the laser is dirty/out of alignment? I have a spare that i might crack open and check out now. One of my buddies might want it. Link to comment Share on other sites More sharing options...
swedishiron Posted April 19, 2010 Report Share Posted April 19, 2010 You can send it off to ALPINE (OEM for the unit) and see if they will repair it, depending on how bad it is they may or may not. I ended up buying one from Eerie no problems with it yet. Link to comment Share on other sites More sharing options...
crazykn Posted April 23, 2010 Report Share Posted April 23, 2010 I actually had to clean mine, using TWO Q-Tips (taped together to extend the length). I opened up the top of the unit, and slide the Q-Tips in and started rubbing and cleaning off the laser head. Working great since! Link to comment Share on other sites More sharing options...
