tallahasseegreys Posted December 7, 2004 Report Share Posted December 7, 2004 Any reliable online retailers?Also, what's wrong with using a regular T40 bit on a 6" extension? Link to comment Share on other sites More sharing options...
theunderlord Posted December 7, 2004 Report Share Posted December 7, 2004 Any reliable online retailers?Also, what's wrong with using a regular T40 bit on a 6" extension?←nothing at all. good luck finding a 7" long T40 bit. haha.. Link to comment Share on other sites More sharing options...
tallahasseegreys Posted December 7, 2004 Author Report Share Posted December 7, 2004 From the Bay13 maintenance section...."Notice in the picture a 7 inch long 40 torx bit is in position on the back 40mm torx screw. The 40mm torx bit makes getting the back screw out without destroying the torx fitting on top of the screw. Get one and use it or your problems will make you wish you did. (3/8 drive)"Is it that a regular T40 bit is too large to fit down there or something? Link to comment Share on other sites More sharing options...
theunderlord Posted December 7, 2004 Report Share Posted December 7, 2004 From the Bay13 maintenance section...."Notice in the picture a 7 inch long 40 torx bit is in position on the back 40mm torx screw. The 40mm torx bit makes getting the back screw out without destroying the torx fitting on top of the screw. Get one and use it or your problems will make you wish you did. (3/8 drive)"Is it that a regular T40 bit is too large to fit down there or something?←ok, I gotcha... You could try an online tool company like Harbor Frieght Link to comment Share on other sites More sharing options...
Phaedrus Posted December 7, 2004 Report Share Posted December 7, 2004 Both Snap-on and Mac tools have them. I have an approx. 6" long set of T handle Torx bits from MSC. They work rather well for the task as well...~JD Link to comment Share on other sites More sharing options...
DEWFPO Posted December 7, 2004 Report Share Posted December 7, 2004 Try sears craftsman online. DEWFPO Link to comment Share on other sites More sharing options...
DashingDaryl Posted December 7, 2004 Report Share Posted December 7, 2004 Here is a link to a past Torx Discussion..Past Discussion on Torx Set.. Link to comment Share on other sites More sharing options...
gdizzle Posted December 7, 2004 Report Share Posted December 7, 2004 http://www.toolsource.com Link to comment Share on other sites More sharing options...
tallahasseegreys Posted December 7, 2004 Author Report Share Posted December 7, 2004 The only online places mentioned on this thread so far that actually had a 3/8" drive extra long (7 to 8 inches) torx 40 bit were snapon and www.toolsource.com.Snap on wants $26.50 for theirs - which comes to over $39 after shipping - yikes, and toolsource wants $14.96. So I ordered one from toolsource, but they unfortunately require a $25 minimum order. So I picked up a 7mm hex bit for when I get the nerve to to a brake job and a stubby screwdriver set. Total for these items after shipping was 33.24.Thanks everyone for your suggestions. Link to comment Share on other sites More sharing options...
parker2520 Posted December 8, 2004 Report Share Posted December 8, 2004 Did I miss something? What was the task at hand? Link to comment Share on other sites More sharing options...
parker2520 Posted December 8, 2004 Report Share Posted December 8, 2004 Ah. Thermostat removal. Nevermind Link to comment Share on other sites More sharing options...
850 Stylzz Posted December 8, 2004 Report Share Posted December 8, 2004 If you have an Autozone near you, they sell a set of "OEM" (brand name) torx keys. You get like 8 for 15 bucks. Mind you, these arent bits, but rather like big allen keys. but it sure did the trick for my thermostat. I use the rest of the set all the time too.caveat though, I broke the plastic handle that is supposed to allow you to apply more torque on the bit. If you brake it too, better have some darn good hand strength or a good pair of vice grips to finish the job. Link to comment Share on other sites More sharing options...
850 Stylzz Posted December 8, 2004 Report Share Posted December 8, 2004 Is it that a regular T40 bit is too large to fit down there or something?←yes. the collar will make it too wide to sit squarely in the bolt Link to comment Share on other sites More sharing options...
msestina Posted December 8, 2004 Report Share Posted December 8, 2004 If you have an Autozone near you, they sell a set of "OEM" (brand name) torx keys. You get like 8 for 15 bucks. Mind you, these arent bits, but rather like big allen keys. but it sure did the trick for my thermostat. I use the rest of the set all the time too.caveat though, I broke the plastic handle that is supposed to allow you to apply more torque on the bit. If you brake it too, better have some darn good hand strength or a good pair of vice grips to finish the job.←when I did my thermo, I bought my long handle torx key set at autozone, when u break the cheap plastic handle, just drill out a wooden dowl and slip it on where the plastic handle was and bette rthen new. Link to comment Share on other sites More sharing options...
KLS Posted December 10, 2004 Report Share Posted December 10, 2004 www.mcmaster.com, catalog page 2609, #6939A87$12.25 + actual UPST40 4" long bit (5" overall length--just right for the t'stat & hatch latch)Ken Link to comment Share on other sites More sharing options...
