fastgp Posted April 21, 2010 Report Share Posted April 21, 2010 i just copped a radio from the junkyard and it doesn't work or something. it's a remanufactured radio and has a sticker on the bottom of it with the date on it. when i plug it up and hit the power button it says "off" in the lil screen. i have the code and everyting but it won't let me even put the code in. now i'm stuck. what can i do? Link to comment Share on other sites More sharing options...
Volvowith18psi Posted April 21, 2010 Report Share Posted April 21, 2010 Leave the radio connected and your ignition turned to "on" but don't start the car. Make sure the radio has juice, leave it this way for 2hours, enter code and win. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 22, 2010 Report Share Posted April 22, 2010 Leave the radio connected and your ignition turned to "on" but don't start the car. Make sure the radio has juice, leave it this way for 2hours, enter code and win. To be more specific, leave the key in pos 1 with the radio turned on displaying "off" You will need to leave it here for 2-3 hours until it displays "code" then you can enter the appropriate code. If you enter a code once and the word code pops back up, don't re-enter the same code, it's not the correct one. You get three shots at this before you start over again. Call your local dealers parts department with the serial number and part number located on top of the radio and they can get you the correct one. Link to comment Share on other sites More sharing options...
BEJinFBK Posted April 22, 2010 Report Share Posted April 22, 2010 To be more specific, leave the key in pos 1 with the radio turned on displaying "off" You will need to leave it here for 2-3 hours until it displays "code" then you can enter the appropriate code. If you enter a code once and the word code pops back up, don't re-enter the same code, it's not the correct one. You get three shots at this before you start over again. Call your local dealers parts department with the serial number and part number located on top of the radio and they can get you the correct one. +1 Link to comment Share on other sites More sharing options...
fastgp Posted April 22, 2010 Author Report Share Posted April 22, 2010 thanks for the input i'll try it when i get off the computer Link to comment Share on other sites More sharing options...
