Volvoboi24 Posted December 8, 2004 Report Share Posted December 8, 2004 Is the 1998 C70 prewired for a CD changer? I have heard that it was.. but I couldnt find it anywhere... anyone know where it is?And will a CD changer from a 1994 855 SC-810 work with the SC-900? Thanks guys Link to comment Share on other sites More sharing options...
c70keeb Posted December 8, 2004 Report Share Posted December 8, 2004 Its located in the trunk its behind the panel that has the light and little cubby for stuff. It might be outside of that but I'm pretty sure I found the hook up behind that panel, on the side where the antenna is the amp is under there too. hope that helps... Link to comment Share on other sites More sharing options...
Volvoboi24 Posted December 8, 2004 Author Report Share Posted December 8, 2004 oh, so its inside the pocket with the light?and did you need a setup kit of some sort to mount the changer? Link to comment Share on other sites More sharing options...
theunderlord Posted December 8, 2004 Report Share Posted December 8, 2004 oh, so its inside the pocket with the light?and did you need a setup kit of some sort to mount the changer?←If it's there, that's where it should be. and, you can fab something relatively easy... Link to comment Share on other sites More sharing options...
c70keeb Posted December 9, 2004 Report Share Posted December 9, 2004 I didn't have the 6 disk changer installed in my car so my wire was behind the pocket with the light I had to pull off that whole panel. Like 5 plastic screws to pull it out. Don't pull too hard b/c the light is obviously wired detatch that and then you can put the panel to the side while you locate the wire. Just find all the wires that go to the amp and it will be right there. Link to comment Share on other sites More sharing options...
