boxpin Posted May 8, 2010 Report Share Posted May 8, 2010 So I went to the wrecker today and found a 93 N/A. Hmmmm, I thought, there are some cams sitting in that engine that would go very nicely in my car. So after removing 30 billion 10mm bolts I walked out(paid) with some N/A cams. I get home and place them next to the Turbo cams I had from my previous engine and I for the life of me cannot tell the difference. I am looking for some sort of lobe difference and I just cant see it. Two options come to mind 1. The cams I pulled from my last engine were N/A cams already and now I have two sets 2. I just wasted a bunch of money. 3. Both 1 and 2. Is there a way to tell, part numbers, mic, something. Link to comment Share on other sites More sharing options...
S8ET6 Posted May 8, 2010 Report Share Posted May 8, 2010 IMO, it looks like they both have similar lift #s, but from the shape of the lobe, the cam on the right (in the last pic) appears to have more duration. Link to comment Share on other sites More sharing options...
98t5M Posted May 8, 2010 Report Share Posted May 8, 2010 AFAIK the difference is like .5mm in lift across all the lobes. Probably pretty hard to spot without a caliper. Link to comment Share on other sites More sharing options...
Jaxx Posted May 8, 2010 Report Share Posted May 8, 2010 dude you're eyeballing cam lobes? use calipers. T5 cams versus GLT cams GLT Intake:250dr duration 8,45mm lift Exhaust:252,6dr duration 8,45mm lift T5 Intake:242dr duration 7,95 lift Exhaust:243,5dr duration 7,95 lift" Link to comment Share on other sites More sharing options...
dublin14 Posted May 8, 2010 Report Share Posted May 8, 2010 dude you're eyeballing cam lobes? use calipers. T5 cams versus GLT cams GLT Intake:250dr duration 8,45mm lift Exhaust:252,6dr duration 8,45mm lift T5 Intake:242dr duration 7,95 lift Exhaust:243,5dr duration 7,95 lift" Whats the Spec for NA cams and does anyone know what the 93 NA cam Specs are? Link to comment Share on other sites More sharing options...
boxpin Posted May 8, 2010 Author Report Share Posted May 8, 2010 I used a caliper this morning and there was about a .44mm difference in the lift. Link to comment Share on other sites More sharing options...
mdlimy Posted May 8, 2010 Report Share Posted May 8, 2010 Whats the Spec for NA cams and does anyone know what the 93 NA cam Specs are? GLT is NA, we are speaking in terms of pre 97 850s. Link to comment Share on other sites More sharing options...
boxpin Posted May 9, 2010 Author Report Share Posted May 9, 2010 Should I put these in or is there a special N/A cam I should be looking for? Link to comment Share on other sites More sharing options...
dublin14 Posted May 9, 2010 Report Share Posted May 9, 2010 GLT is NA, we are speaking in terms of pre 97 850s. Ok, whats the difference between 93 NA cams compared to 94-97 NA cams? Link to comment Share on other sites More sharing options...
Falcone Posted May 11, 2010 Report Share Posted May 11, 2010 the cam gears should be a little thinner on the 93 cams (use a thinner t-belt) Link to comment Share on other sites More sharing options...
the commissar! Posted May 11, 2010 Report Share Posted May 11, 2010 Ok, whats the difference between 93 NA cams compared to 94-97 NA cams? As far as lift and duration... 93 > other NA > T5 Turbo Not sure where a GLT Turbo fits in with that. I read here on VS that you replace the gears with the ones that came on your car so the thinner gears should not make a difference. Link to comment Share on other sites More sharing options...
L8 APEKS Posted May 11, 2010 Report Share Posted May 11, 2010 There are 2 easy ways to tell the difference. 1), mic the lobes from base to tip. The taller lobe is the N/A cam. I think it was a difference of about 2mm IIRC. 2), look at the part numbers on the end of the cams. The part numbers also have INT and EXH on them (or some just have an I and E at the end of the number). The cam gears on my '94 turbo are identical to the cam gears on the '93 N/A. FWIW, I am very happy with the N/A cams now that I sorted out my other issues! Link to comment Share on other sites More sharing options...
dublin14 Posted May 12, 2010 Report Share Posted May 12, 2010 In a nut shell any NA 93-98 cams will work for a 98 T5 engine? Link to comment Share on other sites More sharing options...
Falcone Posted May 12, 2010 Report Share Posted May 12, 2010 yes, in a nutshell. I have them in my car with a six degree advance, love them Link to comment Share on other sites More sharing options...
the commissar! Posted May 13, 2010 Report Share Posted May 13, 2010 yes, in a nutshell. I have them in my car with a six degree advance, love them Falcone, to clarify, are you saying you have both intake and exhaust N/A cams installed and both set on 6* advance? 93 or 94+ N/A cams? Link to comment Share on other sites More sharing options...
