Johann Posted May 14, 2010 Report Share Posted May 14, 2010 guys what do you think that will be the big differnce with the CAT cams??? 60 crank HP on my NA.. Max lift you can find on stock cams is 8.45 mm. Max lift you could reach safely without binding the springs and touching the seals is near 9.5 mm Even then different springs are advised which means the 1200 dollar won't cover all. There's another company called KM Cams offering cams for the 5 cylinder, http://kmcams.com/product_info.php?manufacturers_id=16&products_id=415 Price isn't that much different from CatCams. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted May 14, 2010 Report Share Posted May 14, 2010 60 crank HP on my NA.. Max lift you can find on stock cams is 8.45 mm. Max lift you could reach safely without binding the springs and touching the seals is near 9.5 mm Even then different springs are advised which means the 1200 dollar won't cover all. There's another company called KM Cams offering cams for the 5 cylinder, http://kmcams.com/product_info.php?manufacturers_id=16&products_id=415 Price isn't that much different from CatCams. 60 HP ok I can't say anything,but does the powerband move a bit higher? Link to comment Share on other sites More sharing options...
Johann Posted May 14, 2010 Report Share Posted May 14, 2010 60 HP ok I can't say anything,but does the powerband move a bit higher? A bit yes.. Currently 8K RPM redline. Power starting to drop near 7600 rpm. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 14, 2010 Report Share Posted May 14, 2010 GeraldJ was looking into having some cams reground - maybe it's worth checking with him to see how that's progressing.... Link to comment Share on other sites More sharing options...
fastassvolvo Posted May 14, 2010 Report Share Posted May 14, 2010 GeraldJ was looking into having some cams reground - maybe it's worth checking with him to see how that's progressing.... +1 We should sticky this thread, Im hearing about cams I haven't before! I think most of the USA volvo community was unaware of the CAT cams! Lets get some data in here boys Link to comment Share on other sites More sharing options...
lookforjoe Posted May 14, 2010 Report Share Posted May 14, 2010 +1 We should sticky this thread, Im hearing about cams I haven't before! I think most of the USA volvo community was unaware of the CAT cams! Lets get some data in here boys there have been a number of Cam threads - take a look in this one, it also has reference pics of early/late cams, etc..... Link to comment Share on other sites More sharing options...
volvoskiah Posted May 18, 2010 Report Share Posted May 18, 2010 do n/a cams work in vvt heads?? anyone know? I have a 99 vvt head and 95 na cams Link to comment Share on other sites More sharing options...
lookforjoe Posted May 18, 2010 Report Share Posted May 18, 2010 anyone know? I have a 99 vvt head and 95 na cams No, not without machine work. Look in the thread I linked, there are pics of the cams, the ends/thrust bearings are different Link to comment Share on other sites More sharing options...
