Turbosleeper Posted May 10, 2010 Report Share Posted May 10, 2010 I feel stupid asking this question but where is the fuel filter located? Its not where it is on the fwd 850's Does anyone know? I hope it uses same filter as the one I ordered from fcp Link to comment Share on other sites More sharing options...
crazykn Posted May 10, 2010 Report Share Posted May 10, 2010 If you jack up (and support it with jackstands) the passenger side, it is located behind the sideskirt near the rear passenger side wheel. There is a 10mm bolt that holds the filter to the bracket. The connections on the hoses are quick disconnect, you need to insert a 17mm wrench between the filter and using a prying action, you can pop off the connectors. Before you do any hose removal, use the bleed schrader valve to bleed off pressure (this valve is located a upstream (a few inches away) from the filter and there is one by the fuel injector rail). Its a really easy job, if you have the simple tools. Link to comment Share on other sites More sharing options...
Jaxx Posted May 10, 2010 Report Share Posted May 10, 2010 wear safety glasses just incase.... ask me how I know. Link to comment Share on other sites More sharing options...
erikv11 Posted May 10, 2010 Report Share Posted May 10, 2010 ... It's not where it is on the fwd 850's ... ... behind the sideskirt near the rear passenger side wheel. ... so I'm just curious, on the AWD is it in the regular place (rear passenger) or not? Link to comment Share on other sites More sharing options...
crazykn Posted May 11, 2010 Report Share Posted May 11, 2010 Lol, I guess I could've read the first post a bit better. The Fuel filter is more upstream than the FWD. If i remember, its in a tougher to reach spot, namely near the rear axle. It might covered by a protective cover. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 11, 2010 Report Share Posted May 11, 2010 If you jack up (and support it with jackstands) the passenger side, it is located behind the sideskirt near the rear passenger side wheel. There is a 10mm bolt that holds the filter to the bracket. The connections on the hoses are quick disconnect, you need to insert a 17mm wrench between the filter and using a prying action, you can pop off the connectors. Before you do any hose removal, use the bleed schrader valve to bleed off pressure (this valve is located a upstream (a few inches away) from the filter and there is one by the fuel injector rail). Its a really easy job, if you have the simple tools. Not on an AWD. It's a PITA It's up above the subframe. You have to remove the interior access panel (where the pump access would be if it were FWD) to get the line off the front, and undo the securing clamp, then get the rear line from underneath. It's not the same filter as FWD. Link to comment Share on other sites More sharing options...
Turbosleeper Posted May 11, 2010 Author Report Share Posted May 11, 2010 Ill take another look. Ive replaced tons of these on fwd 850's but this awd thing is starting to really piss me off lol. thx for the replies Link to comment Share on other sites More sharing options...
