Pops Racer Posted May 11, 2010 Report Share Posted May 11, 2010 2002 S60 2.4T. AWD AT 13g. Wife says tranny sounds funny some times, and doesn't shift properly. I cant duplicate her issues. I will Flush ASAP per Chilled mans directive. Exhaust burbles. Where do I get exhaust parts ? FCP has none. How much before I have to do PCV and Tbelt? Money pittage, as V4LVE says. Link to comment Share on other sites More sharing options...
shanks31 Posted May 11, 2010 Report Share Posted May 11, 2010 i have a stock 2.4t system with the resonator deleted if you need a new stock exhaust Link to comment Share on other sites More sharing options...
Pops Racer Posted May 11, 2010 Author Report Share Posted May 11, 2010 How loud and how much? its my wifes car, she dont like noise. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 12, 2010 Report Share Posted May 12, 2010 A better description of the noise is needed, otherwise we are simply guessing :) Link to comment Share on other sites More sharing options...
Pops Racer Posted May 12, 2010 Author Report Share Posted May 12, 2010 I know what it is, its a hole in rear muffler/pipe area. So I need to replace both. Its raining now, so I will crawl under car later on and see configuration. I just need stock stuff. And tranny flush pretty similar to 850? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 12, 2010 Report Share Posted May 12, 2010 And tranny flush pretty similar to 850? Yup, except you pull the bottom line off. Be sure to use the Mobil 3309 fluid as well, generally it's 12-14qts. Link to comment Share on other sites More sharing options...
Chilled man Posted May 12, 2010 Report Share Posted May 12, 2010 Same just make sure to use only the 3309 fluid Link to comment Share on other sites More sharing options...
shanks31 Posted May 12, 2010 Report Share Posted May 12, 2010 It really is no louder than stock, just flows a little better. If you tell me which section you need i can cut it at whatever point you want and ship it that way. Link to comment Share on other sites More sharing options...
shanks31 Posted May 12, 2010 Report Share Posted May 12, 2010 figure 175-200 shipped pending on how much of the exhaust you want. Rockauto.com has it for 400 w/o shipping just for the rear muffler for reference Link to comment Share on other sites More sharing options...
Dan A Posted May 13, 2010 Report Share Posted May 13, 2010 Do your tbelt now along with tensioner. Link to comment Share on other sites More sharing options...
Pops Racer Posted May 13, 2010 Author Report Share Posted May 13, 2010 Yup, except you pull the bottom line off. Be sure to use the Mobil 3309 fluid as well, generally it's 12-14qts. 12-14 qts is flush AND fill, right? Thanks to you guys for the input, specially Justin. figure 175-200 shipped pending on how much of the exhaust you want. Rockauto.com has it for 400 w/o shipping just for the rear muffler for reference PM sent! Do your tbelt now along with tensioner. Will do!, checking FCP now. Link to comment Share on other sites More sharing options...
Mesoam Posted May 17, 2010 Report Share Posted May 17, 2010 a pin size hole? just tac weld it, test the rest of the area for rot though Link to comment Share on other sites More sharing options...
Pops Racer Posted May 17, 2010 Author Report Share Posted May 17, 2010 I'm crawling under it tonight, it seems to be by the first resonator flange to the cat. we shall see. Link to comment Share on other sites More sharing options...
Pops Racer Posted May 18, 2010 Author Report Share Posted May 18, 2010 Front resonator split like a grinder roll. Link to comment Share on other sites More sharing options...
