Fake-R Posted May 20, 2010 Report Share Posted May 20, 2010 I'm having a hell of a time taking the old pulley off, and am just wondering what methods you've used to overcome this. Tried nearly everything, from putting the car in car, and holding the brake, to trying to hold the pulley with a punch, but it just won't work. Might give an impact a try tomorrow, but anything else incase that fails? Link to comment Share on other sites More sharing options...
JCviggen Posted May 20, 2010 Report Share Posted May 20, 2010 Impact gun should work. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted May 20, 2010 Report Share Posted May 20, 2010 Impact gun to get the bolt off and then dead blow hammer to knock it loose. Link to comment Share on other sites More sharing options...
the commissar! Posted May 20, 2010 Report Share Posted May 20, 2010 Yep, I had the same trouble and even my old air gun wouldn't knock it loose, so I went to Harbor Freight and got a 625 ft/# rated one for ~$75 and that did the trick. Once bolt was off I didn't even need the deadblow... Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted May 20, 2010 Report Share Posted May 20, 2010 Impact gun for sure. Not sure how powerful/quality the gun I was using was, but I had to hold it on there, trigger down, for a few seconds before it broke free. Link to comment Share on other sites More sharing options...
BurgerBob Posted May 20, 2010 Report Share Posted May 20, 2010 Just in case anyone only reads the last post, impact gun. Link to comment Share on other sites More sharing options...
Chilled man Posted May 20, 2010 Report Share Posted May 20, 2010 Electric Impact guy also some heat and WD40 Link to comment Share on other sites More sharing options...
bum2kev Posted May 20, 2010 Report Share Posted May 20, 2010 Screwdriver in the flywheel and breaker bar if you donpt have an impact. There is a spot in the back of the trans where you can lock the screwdriver in the flywheel Link to comment Share on other sites More sharing options...
Fake-R Posted May 20, 2010 Author Report Share Posted May 20, 2010 Screwdriver in the flywheel and breaker bar if you donpt have an impact. There is a spot in the back of the trans where you can lock the screwdriver in the flywheel Dammit. I didn't think of the flywheel. Well, if the impact doesn't do the trick, that's what I'll try. Link to comment Share on other sites More sharing options...
bum2kev Posted May 20, 2010 Report Share Posted May 20, 2010 Why are you taking off the ur pulley? Link to comment Share on other sites More sharing options...
Fake-R Posted May 20, 2010 Author Report Share Posted May 20, 2010 Why are you taking off the ur pulley? Trying to put it on, not take it off, haha. Need any help I can get for the dyno this Saturday. Link to comment Share on other sites More sharing options...
v4lve Posted May 20, 2010 Report Share Posted May 20, 2010 Electric Impact guy also some heat and WD40 Apply heat with WD40 via lighter and spray can Link to comment Share on other sites More sharing options...
MyCarIsRed Posted May 21, 2010 Report Share Posted May 21, 2010 Apply heat with WD40 via lighter and spray can :lol: Don't forget to kick the dog while your at it. Link to comment Share on other sites More sharing options...
Young Burnsy Posted May 21, 2010 Report Share Posted May 21, 2010 eff WD40 My Vulva prefers :lol: Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted May 21, 2010 Report Share Posted May 21, 2010 eff WD40 My Vulva prefers fail. you have to use the warming kind duh. Link to comment Share on other sites More sharing options...
