magicaljake Posted May 24, 2010 Author Report Share Posted May 24, 2010 What RPM does the dip begin at? Can't see anything from the pics. thats like 4100 rpmon another forum somone said somethign about spark plugs.. and i just relized that i have never replaced anything in the ignition system..... i have owned the car for 13 months and have put 32,000 miles on.... any idea if that could have anything to do with it? oh.. and when my car came off the dyno the CEL, ABS, TRACS lights were all on.... but went off by the time i got to the hotel Link to comment Share on other sites More sharing options...
lookforjoe Posted May 24, 2010 Report Share Posted May 24, 2010 thats like 4100 rpm on another forum somone said somethign about spark plugs.. and i just relized that i have never replaced anything in the ignition system..... i have owned the car for 13 months and have put 32,000 miles on.... any idea if that could have anything to do with it? oh.. and when my car came off the dyno the CEL, ABS, TRACS lights were all on.... but went off by the time i got to the hotel Definitely replace cap, rotor, plugs! If it's happening around peak torque area, makes perfect sense. BKR7E's work wonderfully, and are inexpensive. I'd only use Bosch cap & rotor. Link to comment Share on other sites More sharing options...
sconeman Posted May 24, 2010 Report Share Posted May 24, 2010 It's good to replace/regap plugs 10-15K or even more often when your running high boost pressures. I do mine about every year. I had some blowout under load at 17 psi in the white car and it scared the crap out of me. +1 on the NGK's and they're about 1 heat range colder I believe look into getting an EBC to control that boost better too you don't want to melt a piston or bend a rod Link to comment Share on other sites More sharing options...
magicaljake Posted May 24, 2010 Author Report Share Posted May 24, 2010 ok.. lets just say that the dip is due to my ignition system.... do you guys think its safe to assume that the lack of power on the top end has something to do with the same? thanks for all your help/oppinions guys Link to comment Share on other sites More sharing options...
fischmama Posted May 24, 2010 Report Share Posted May 24, 2010 ABS TRAC light seems to be normal after running on a dyno. I read mine and it noticed a speed difference between the front and rear tires for an extended amount of time a threw a speedsensor codes for the rears. Codes will still be stored but not as a permanent if you drive a bit and it gets proper data again from the rear. I would not read into the dyno chart to much since what happened was probably registered by the ECU somehow and affected the rest of the run. Link to comment Share on other sites More sharing options...
caanglin Posted May 24, 2010 Report Share Posted May 24, 2010 ok.. lets just say that the dip is due to my ignition system.... do you guys think its safe to assume that the lack of power on the top end has something to do with the same? My car would "blow out" at 19psi @ 4k+. Then I replaced the plugs, rotor and distributor cap and it hasn't happened since. It's a cheap and easy place to start. Link to comment Share on other sites More sharing options...
magicaljake Posted May 24, 2010 Author Report Share Posted May 24, 2010 thanks guys... this exactly the type of help i was hoping for.... i will replace/ the entire ignition system withen the next couple weeks... then bring it up to the track.... [can you say 13's? ] i have like 10+ 14.0's soo im due haha... Link to comment Share on other sites More sharing options...
Auburn T5 Posted May 24, 2010 Report Share Posted May 24, 2010 My car would "blow out" at 19psi @ 4k+. Then I replaced the plugs, rotor and distributor cap and it hasn't happened since. It's a necessary and mandatory parts set replacement every 15K miles. fixed :D Link to comment Share on other sites More sharing options...
Captain Bondo Posted May 25, 2010 Report Share Posted May 25, 2010 do you guys think its safe to assume that the lack of power on the top end has something to do with the same? Hard to say. usually it'll pick back up again highe rin the rev range when the VE drop and the charge gets less dense. What turbo and what cams? Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted May 25, 2010 Report Share Posted May 25, 2010 Definitely replace cap, rotor, plugs! If it's happening around peak torque area, makes perfect sense. BKR7E's work wonderfully, and are inexpensive. I'd only use Bosch cap & rotor. j/w are these the 4644 plugs for s70's? Link to comment Share on other sites More sharing options...
rbodor3 Posted May 25, 2010 Report Share Posted May 25, 2010 great torque numbers!!! :D Link to comment Share on other sites More sharing options...
Kevin. Posted May 25, 2010 Report Share Posted May 25, 2010 It's a necessary and mandatory parts set replacement every 15K miles. you sure about that? that's seems very low to me Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted May 25, 2010 Report Share Posted May 25, 2010 so i must be extremely wasteful my plugs get exhanged every other oil change and in the last year ive put on 3 sets of plug wires. not because of issues but because i just like knowing theres no wee little shinanagins brewin. so if i were to go the NGK BKR7E route they are 1 heat range colder than the bosch super + coppers i use? Link to comment Share on other sites More sharing options...
lookforjoe Posted May 25, 2010 Report Share Posted May 25, 2010 j/w are these the 4644 plugs for s70's? Yes. so i must be extremely wasteful my plugs get exhanged every other oil change and in the last year ive put on 3 sets of plug wires. not because of issues but because i just like knowing theres no wee little shinanagins brewin. so if i were to go the NGK BKR7E route they are 1 heat range colder than the bosch super + coppers i use? 3 sets of wires? That's nuts. Get one set of kingsborne/IPD & be done with it. Wires should last 60K without any problems. The 7E's are one range colder. Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted May 25, 2010 Report Share Posted May 25, 2010 i have the kingsborne now i was just very wasteful but it helped me sleep at night. The kingsbornes are on now along with cap rotor coil blah blah. They will be on there for a while. ill be getting the BKR7E tonight cause im due for my 2nd oil change switcharoo . im still takin your word an snagging a MSD6A ;) Link to comment Share on other sites More sharing options...
