bum2kev Posted June 16, 2010 Report Share Posted June 16, 2010 How long would we have to make the elbows? its not the legs and its not a 90deg hose. its around a 100 to 110deg Link to comment Share on other sites More sharing options...
the commissar! Posted June 23, 2010 Report Share Posted June 23, 2010 its not the legs and its not a 90deg hose. its around a 100 to 110deg I respectfully disagree. Yes, it is 110 deg, and you cannot find a reducer elbow 90 deg with legs that are long enough to fit if you want to force 90 deg to work. Standard L sure but not a reducer. A 90 deg reducer L with long legs could be forced to work but it is not a properly fitting piece. Link to comment Share on other sites More sharing options...
bum2kev Posted June 23, 2010 Report Share Posted June 23, 2010 i bought a 90 deg elbow reducer and almost got it to fit. the legs on the one i got were good enough there was just no way to get it to work at the angles provided on the IPD lower pipe. it def needs to be 100 110. Link to comment Share on other sites More sharing options...
the commissar! Posted June 23, 2010 Report Share Posted June 23, 2010 i bought a 90 deg elbow reducer and almost got it to fit. the legs on the one i got were good enough there was just no way to get it to work at the angles provided on the IPD lower pipe. it def needs to be 100 110. Exactly...but if that leg were longer it should have enough give to distort but attach (avoided using the word fit here)... Cheers on finding a source for an off the shelf L reducer with the proper ID for both ends...I looked for many hours to find one without success. Where? I want to bookmark that site for future projects. I know that you and I and many others want to have a one piece solution so StylinMotors hook us up! BTW...if you want to borrow one for a template, I'll send you mine if you promise to send it back in one piece, and I'll test fit your your bigger TB design Michael Link to comment Share on other sites More sharing options...
bum2kev Posted June 23, 2010 Report Share Posted June 23, 2010 Exactly...but if that leg were longer it should have enough give to distort but attach (avoided using the word fit here)... Cheers on finding a source for an off the shelf L reducer with the proper ID for both ends...I looked for many hours to find one without success. Where? I want to bookmark that site for future projects. I know that you and I and many others want to have a one piece solution so StylinMotors hook us up! BTW...if you want to borrow one for a template, I'll send you mine if you promise to send it back in one piece, and I'll test fit your your bigger TB design Michael i spent waaaay to much on it. but i got it from here. http://www.turbohoses.com/ they will also do custom applications for not too much. but i was fine with just throwing an extra reducer at my setup as i had one laying around. Link to comment Share on other sites More sharing options...
the commissar! Posted June 24, 2010 Report Share Posted June 24, 2010 i spent waaaay to much on it. but i got it from here. http://www.turbohoses.com/ they will also do custom applications for not too much. but i was fine with just throwing an extra reducer at my setup as i had one laying around. I'll say...$85 for a stock transition! Whew, that silicone must have come from Pamela Andersen's implants The radius on those is very small and the transition is very quick, I see why forcing it would difficult. Thanks for the new to me source. I have not stumbled onto that one. Link to comment Share on other sites More sharing options...
bum2kev Posted June 24, 2010 Report Share Posted June 24, 2010 I'll say...$85 for a stock transition! Whew, that silicone must have come from Pamela Andersen's implants The radius on those is very small and the transition is very quick, I see why forcing it would difficult. Thanks for the new to me source. I have not stumbled onto that one. i was able to return it though since they are local. Link to comment Share on other sites More sharing options...
