Turbosleeper Posted June 1, 2010 Report Share Posted June 1, 2010 Alright so Im not new to the car audio world whatsoever but I am curious as to where the factory amp is located on the premium sound systems. I have a basic alpine mp3 deck to install and am curious if I can run the factory amp with it. I was originall going to use a wire harness adapter but the smaller connector on the volvo side only has one single wire running from it(yellow/black) if Im not mistaken. Please help Thanks, James Link to comment Share on other sites More sharing options...
drin850 Posted June 1, 2010 Report Share Posted June 1, 2010 the factory amp is located just under the headunit/infront of the heater core. you can access it the same way you would access the heater core. I'm pretty sure you can't use the factory amp with an aftermarket deck (probably why i removed mine). not a big deal since most new decks are over 200watts. once you unplug the amp you'll have the second harness to plug into the new deck. Adrian Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 1, 2010 Report Share Posted June 1, 2010 can i have your harness then cause i need an amp harness so feel free not to throw it out Link to comment Share on other sites More sharing options...
Turbosleeper Posted June 2, 2010 Author Report Share Posted June 2, 2010 Thanks! Ill give it a shot 2moro Sorry I wont be cutting out the harness Link to comment Share on other sites More sharing options...
EastsideR Posted June 2, 2010 Report Share Posted June 2, 2010 can i have your harness then cause i need an amp harness so feel free not to throw it out Hey there. I have an extra harness if you need one. I cant do anything with it, since I already had another harness. Just let me know, as it is still in the box it came in. Link to comment Share on other sites More sharing options...
HPTDoh Posted June 2, 2010 Report Share Posted June 2, 2010 Alright so Im not new to the car audio world whatsoever but I am curious as to where the factory amp is located on the premium sound systems. I have a basic alpine mp3 deck to install and am curious if I can run the factory amp with it. I was originall going to use a wire harness adapter but the smaller connector on the volvo side only has one single wire running from it(yellow/black) if Im not mistaken. Please help Thanks, James I have an adapter to use an aftermarket HU with the OEM amp that I never used. PM me if interested Link to comment Share on other sites More sharing options...
