mrbrightside2009 Posted June 5, 2010 Report Share Posted June 5, 2010 Jim, pre-detonation? Yes, that would be detonation. Also, you can run a bunch of boost down low if you have a tune set up for it, and a system that can keep boost spikes under control. well mine doesn't kick in too low and i really don't get any boost spikes with my controller. Link to comment Share on other sites More sharing options...
ozzimark Posted June 5, 2010 Report Share Posted June 5, 2010 well mine doesn't kick in too low and i really don't get any boost spikes with my controller. Yeah, but the LPT has higher compression than the HPT ECU you're running is tuned for, ignition is gonna be too advanced, and fueling will be off a bit. Link to comment Share on other sites More sharing options...
faultywarrior Posted June 5, 2010 Report Share Posted June 5, 2010 I don't know what the face was implying, but yes. Pre-detonation. As in when the intake air being blasted in from the turbo is so hot, when fuel mixes with it, it goes boom before it gets into the cylinder. Bent rods and prob. bent everything else. I'm sure most of you knew what I meant, but I wanted to make myself clearly understood. Link to comment Share on other sites More sharing options...
ozzimark Posted June 5, 2010 Report Share Posted June 5, 2010 I don't know what the face was implying, but yes. Pre-detonation. As in when the intake air being blasted in from the turbo is so hot, when fuel mixes with it, it goes boom before it gets into the cylinder. Bent rods and prob. bent everything else. I'm sure most of you knew what I meant, but I wanted to make myself clearly understood. I figured that's what you were talking about. There's no "pre" in detonation. To clarify, there's detonation and pre-ignition. Detonation is when the air/fuel mix literally explodes, when what is wanted is a controlled burn with a normal flame front propagation. Pre-ignition is the burning, not explosion, of the air/fuel mix before desired, which is still bad, but not nearly as dangerous as detonation. This might be good reading for anyone not up with the subject http://www.streetrodstuff.com/Articles/Engine/Detonation/ Link to comment Share on other sites More sharing options...
ErikS Posted June 5, 2010 Report Share Posted June 5, 2010 We'll be able to put this issue to rest in a few weeks stay tuned folks my 00 R motor w/ bent rods is coming out and a new experiment is going in Dual Hampsters in exercise wheels swap? Unlike your motors, they usually live 6-12 months. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted June 5, 2010 Report Share Posted June 5, 2010 Dual Hampsters in exercise wheels swap? Unlike your motors, they usually live 6-12 months. Thats generally the life span of my motor's anyways :lol: Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted June 5, 2010 Report Share Posted June 5, 2010 Yeah, but the LPT has higher compression than the HPT ECU you're running is tuned for, ignition is gonna be too advanced, and fueling will be off a bit. so what do you suggest i do to fix the advanced ignition without getting a tune right now? Link to comment Share on other sites More sharing options...
ozzimark Posted June 5, 2010 Report Share Posted June 5, 2010 so what do you suggest i do to fix the advanced ignition without getting a tune right now? Live with it and accept the possible danger, turn down the boost, or run water/meth injection. If I were you, I'd just live with it, and save up for a real dyno tune :lol: Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted June 5, 2010 Report Share Posted June 5, 2010 Live with it and accept the possible danger, turn down the boost, or run water/meth injection. If I were you, I'd just live with it, and save up for a real dyno tune ok lol, eventually i'll get a tune, im only running 13psi right now, im not going crazy with it lol. Link to comment Share on other sites More sharing options...
faultywarrior Posted June 5, 2010 Report Share Posted June 5, 2010 ok lol, eventually i'll get a tune, im only running 13psi right now, im not going crazy with it lol. 13 isn't bad. A meth kit would help a bit. Just don't run 50/50! Link to comment Share on other sites More sharing options...
98 s70 t5m Posted June 5, 2010 Report Share Posted June 5, 2010 I figured that's what you were talking about. There's no "pre" in detonation. To clarify, there's detonation and pre-ignition. Detonation is when the air/fuel mix literally explodes, when what is wanted is a controlled burn with a normal flame front propagation. Pre-ignition is the burning, not explosion, of the air/fuel mix before desired, which is still bad, but not nearly as dangerous as detonation. This might be good reading for anyone not up with the subject http://www.streetrodstuff.com/Articles/Engine/Detonation/ Did you read the article you linked to? It says Pre-ignition is basically the death of an engine. Anyhow I think detonation bends rods so water injection would help alot with detonation and thus offer protection against bent rods. Link to comment Share on other sites More sharing options...
ozzimark Posted June 5, 2010 Report Share Posted June 5, 2010 It says Pre-ignition is basically the death of an engine. It can be, but since the burn rate of the air/fuel mix is slower, it's not as dangerous as detonation; it doesn't raise the cylinder pressure quite as quickly before TDC. But yes, both are bad :lol: Link to comment Share on other sites More sharing options...
