ohsleeper Posted June 6, 2010 Report Share Posted June 6, 2010 i'm pretty sure this has been done but i dont know how to search for what i'm looking for. what i would like is to be able to run my amber corners and fogs alone as daytime running lights. i do not have fogs yet so i'm not sure what their stock functions are. i assume they just run whenever you have low beams on? thanks Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted June 6, 2010 Report Share Posted June 6, 2010 http://volvospeed.com/Mods/850_foglights.html its the same for 98 S70s as for 850s. Result is this: Link to comment Share on other sites More sharing options...
ohsleeper Posted June 6, 2010 Author Report Share Posted June 6, 2010 so when you do that the corners stay illuminated also? even when your low or high beams are off? Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted June 6, 2010 Report Share Posted June 6, 2010 Well basically it lets you turn the fogs on while the parking lights are on. Before if you had the headlight switch in the middle position (parking lights) your fogs automatically turn off. Same with high beams. This mod allows the fog lights to stay on through parking lights, low beams, and highs. Link to comment Share on other sites More sharing options...
bob850 Posted June 7, 2010 Report Share Posted June 7, 2010 Has anyone figured out a way to have the above functionality, but with the additional feature that the fogs & corners will turn off when the ignition is off? I have done the mod, but don't really use it because I'm afraid of forgetting to turn them off when I get out of the car. Currently, if the headlight switch is in the top position, the lights will turn off when the car is off, but if the headlight switch is in the middle position, the fogs and corners will stay on even if the car is off. Link to comment Share on other sites More sharing options...
gavtodd Posted June 7, 2010 Report Share Posted June 7, 2010 http://volvospeed.com/Mods/850_foglights.html its the same for 98 S70s as for 850s. Result is this: Where does one get your lights and corners? Those look sick Link to comment Share on other sites More sharing options...
ohsleeper Posted June 7, 2010 Author Report Share Posted June 7, 2010 Has anyone figured out a way to have the above functionality, but with the additional feature that the fogs & corners will turn off when the ignition is off? I have done the mod, but don't really use it because I'm afraid of forgetting to turn them off when I get out of the car. Currently, if the headlight switch is in the top position, the lights will turn off when the car is off, but if the headlight switch is in the middle position, the fogs and corners will stay on even if the car is off. i can see this being an issue with just the parking lights...but i doubt you will walk a way from your car with the fogs on and not notice...on a similar note...are there higher output amber bulbs for the corners? Link to comment Share on other sites More sharing options...
loudatom Posted June 8, 2010 Report Share Posted June 8, 2010 Where does one get your lights and corners? Those look sick Projector retrofit with e-codes and clear turns? On a separate note, does this mod work with the 99+ relay? Link to comment Share on other sites More sharing options...
