tharam04 Posted June 7, 2010 Report Share Posted June 7, 2010 The antenna mast on my '95 850 doesn't move when the radio is turned on or off. If I manually move adjust it, it will extend to the full length at the highest point and about 1/2 of the way down at the lowest point. The motor works fine because it can be heard running when the ignition is switched on or off. Any suggestions on how to fix this problem? Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 7, 2010 Report Share Posted June 7, 2010 your mast has broken, you must obtain a new mast remove your motor assembly be sure all the broken peices are out and install a new one, its a very simple job dont worry Link to comment Share on other sites More sharing options...
Kevin. Posted June 7, 2010 Report Share Posted June 7, 2010 Mine works about 50% of the time I prob need to do that Link to comment Share on other sites More sharing options...
lengendsecko87 Posted June 7, 2010 Report Share Posted June 7, 2010 Open up the mast assembely and clean it out. I had broken mast in there before, cleaned it out, and it works like a charm now. Link to comment Share on other sites More sharing options...
tharam04 Posted June 9, 2010 Author Report Share Posted June 9, 2010 I disconnected the antenna mast from the car. The plastic cord inside the mast had broken inside the mast and thereby keeping it up all the time. I have ordered a new one and post how the installation goes. Link to comment Share on other sites More sharing options...
Burn-E Posted June 9, 2010 Report Share Posted June 9, 2010 Here's the VS Bay 13 write-up for how to do this job - also look a few threads down in Audio Video and you'll find another discussion of how the plastic mast gearing may not grab initially but will take persistence. Link to comment Share on other sites More sharing options...
tharam04 Posted June 12, 2010 Author Report Share Posted June 12, 2010 I got the antenna in installed, but it doesn't go all the way in. Sometimes it varies in how far down it will go. I've tried pushing down on it after the motor has stopped, but I can't get it to go down any further. Suggestions? Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 15, 2010 Report Share Posted June 15, 2010 Ugh, disassemble the motor casing and remove all the broken pieces. I promise you there is some in there. This is the only thing that is going to fix your antenna. Link to comment Share on other sites More sharing options...
tharam04 Posted June 15, 2010 Author Report Share Posted June 15, 2010 --Aaron-- I did that before putting the new one in. The part of the cord that had broken off came out all in one piece. Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 15, 2010 Report Share Posted June 15, 2010 --Aaron-- I did that before putting the new one in. The part of the cord that had broken off came out all in one piece. As long as you're 100% sure that all the old, broken mast is removed then just keep at it and be patient. Sometimes it takes a little to get the cord to wind in nice and smooth. If there's no remnants in the motor casing there's nothing there stopping the new mast from drawing in as it should. Patience. It's ok, I'm really impatient myself. :lol: Link to comment Share on other sites More sharing options...
tharam04 Posted June 17, 2010 Author Report Share Posted June 17, 2010 As long as you're 100% sure that all the old, broken mast is removed then just keep at it and be patient. Sometimes it takes a little to get the cord to wind in nice and smooth. If there's no remnants in the motor casing there's nothing there stopping the new mast from drawing in as it should. Patience. It's ok, I'm really impatient myself. I'll probably attempt to work with it again over the weekend. One thing that I have noticed is that it doesn't always go down the same distance everytime. Sometimes it's higher and other times it's lower. Link to comment Share on other sites More sharing options...
