harleyhv Posted June 8, 2010 Report Share Posted June 8, 2010 I'm in the process of installing a boost gauge in my car. I considered many options: * A-Pillar: not sure if I want to drill a hole through it * CF Werk: installation may be quite a B...ch from what I gathered * Air Vent: need the vent too much up here in winter * IPD: a "little" on the expansive side for a pod but good location... So I decided to try to build my own dash mough gauge pod from an universal A-pillar pod and follow IPD's install procedure.. Here are some preliminary "concept" pics: Some comments: * I molded the pod with a heat gun and I still have to do some adjustments in the back to let the wire through. * I found some stretchable material locally that match as closely as possible the "tan" interior (may be a little darker). * I did not glue the material yet as I'm still figuring out the way to stretch it / sow it properly to the pod (as you can see on the left side of the gauge). * I'm not sure if I should use a flat lacquer or keep the material as is once glued to the pod. * I'm considering double sided tape to fix the pod to the dash. Any comments / Suggestions are welcome thanks Link to comment Share on other sites More sharing options...
sacrifice Posted June 8, 2010 Report Share Posted June 8, 2010 not bad...but is that a dress sock? Link to comment Share on other sites More sharing options...
Oreo931 Posted June 8, 2010 Report Share Posted June 8, 2010 not bad...but is that a dress sock? Was gonna ask the same thing I think it looks OK as of now...Not ghetto, but not far from it...I would have used a different material though. It's the overlapping material I don't like btw. Link to comment Share on other sites More sharing options...
harleyhv Posted June 8, 2010 Author Report Share Posted June 8, 2010 not bad...but is that a dress sock? lol now that you mention it, it does look quite similar to a dress sock... That would have save me some time going through a local "fabric" store. It's the back of a "floral" print material. Link to comment Share on other sites More sharing options...
harleyhv Posted June 8, 2010 Author Report Share Posted June 8, 2010 Was gonna ask the same thing I think it looks OK as of now...Not ghetto, but not far from it...I would have used a different material though. It's the overlapping material I don't like btw. I don't like it too... That's the overlap that I have to eliminate somehow.. I still have to play with the material to see where the best place the stich should be... probably straight under the gauge as with what tomedkaz did on swedespeed: http://forums.swedes...-new-pillar-pod Link to comment Share on other sites More sharing options...
harleyhv Posted June 13, 2010 Author Report Share Posted June 13, 2010 Newb question to follow: I just installed my boost gauge (52mm Omori, electric -30 to 25 lbs readings) and I want to validate with you guys if it is working properly. 1) when I turn the key to position 2. the gauge goes to zero (0) 2) when I starts the car, it goes to -30 to settle to -20 lbs 3) on hard acceleration, it goes up to 14-15 lbs (which I think is normal considering my 2.4 lpt with autotech tune). 4) when I stop the engine, the gauge goes back to -30 lbs Now, is this bahaviour ok? I'm asking this question because I was under the impression that gauge would remain at around zero when the engine is running (and not -20) Link to comment Share on other sites More sharing options...
gilber33 Posted June 13, 2010 Report Share Posted June 13, 2010 Mine sits at ~-20 when I'm idling, cruising it's at about -10ish, give or take, and when accelerating it does whatever I tell it to. Link to comment Share on other sites More sharing options...
harleyhv Posted June 14, 2010 Author Report Share Posted June 14, 2010 Mine sits at ~-20 when I'm idling, cruising it's at about -10ish, give or take, and when accelerating it does whatever I tell it to. Thanks Seems that the gauge is reading properly. Now, I just have to install the material to the gauge in a proper way Link to comment Share on other sites More sharing options...
MyCarIsRed Posted June 14, 2010 Report Share Posted June 14, 2010 I have mine mounted there as well, sunk into the 850 pocket. I find it much easier to keep an eye on there, the pillars are so big anyways i don't want them any larger. It only raises up about 1.5" above normal height tho, and is hard to see from front or back. I used a piece of 2" id pvc pipe, slit lengthwise so the gauge would fit in. Link to comment Share on other sites More sharing options...
