stevensane247 Posted June 9, 2010 Report Share Posted June 9, 2010 Can't find anything on here, I need some help on here on how to mount it up? I got the harness adapter, but what do I to tap into stock amp? Splice into wiring on amp plug? Any info on install basically.. It's a kenwood dd Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted June 9, 2010 Report Share Posted June 9, 2010 More information on your car is needed. If it has the amp from the factory, im not sure if it can be used. someone else would answer that. If it doesnt have the amp from the factory, then its just simply get a wire harness from bestbuy and match the colors and go Link to comment Share on other sites More sharing options...
BEJinFBK Posted June 9, 2010 Report Share Posted June 9, 2010 I posted some info on this very topic a few days ago over at MVS: http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=30204 Maybe it'll help. ;) Link to comment Share on other sites More sharing options...
Mesoam Posted June 10, 2010 Report Share Posted June 10, 2010 Member Crazykn can make you an adapter for the HU and stock AMP, this is the route I went Link to comment Share on other sites More sharing options...
stevensane247 Posted June 10, 2010 Author Report Share Posted June 10, 2010 HU? Is that something that attaches to amp plug to wire to my aftermarket stereo?It's the 3 disc changer radio sc-900 I think? Has amp plug in back of radio Link to comment Share on other sites More sharing options...
Mesoam Posted June 10, 2010 Report Share Posted June 10, 2010 HU = head unit Link to comment Share on other sites More sharing options...
stevensane247 Posted June 10, 2010 Author Report Share Posted June 10, 2010 Derrrrr dumazz moment Link to comment Share on other sites More sharing options...
stevensane247 Posted June 30, 2010 Author Report Share Posted June 30, 2010 So the deck is installed, but the weird thing is that everynow and then when I remove key it still stays powered on like key is in accessory mode, the heater controls are still active but once I adjust fan on heater it shuts everything down.. Guessing stuck solenoid? Link to comment Share on other sites More sharing options...
BEJinFBK Posted July 2, 2010 Report Share Posted July 2, 2010 Which HU? You mention a Kenwood AND an SC-901... If you replaced an SC-901 with a Kenwood, did you use a harness adapter? And if ya did, are you sure it's all connected correctly? Any Pics? Sounds like a power wire may be connected to the wrong thing. Seeing what is spliced to what would help. Link to comment Share on other sites More sharing options...
stevensane247 Posted July 2, 2010 Author Report Share Posted July 2, 2010 Went from a sc900 to a kenwood dd ddx7015, used the wiring harness with amp bypass. Not too much of a big deal it's just weird Link to comment Share on other sites More sharing options...
BEJinFBK Posted July 3, 2010 Report Share Posted July 3, 2010 Went from a sc900 to a kenwood dd ddx7015, used the wiring harness with amp bypass. Not too much of a big deal it's just weird Sometimes the constant and switched power on those harness kits is backwards. You might check that. You could be back feeding into the electrical system from the deck. Try unplugging the Kenwood and see what happens to the heater controls then. Link to comment Share on other sites More sharing options...
Guest Steve Quigley Posted July 3, 2010 Report Share Posted July 3, 2010 It rarely happens though, Link to comment Share on other sites More sharing options...
