mulcy Posted June 16, 2010 Report Share Posted June 16, 2010 I need help with a couple of small items as I'm finishing up a swap on the 98 T5M. I broke the hose that connects the Air pump at the front left of the car to the SAS valve back by the turbo. I don't have access to Vadis since I've got a mac. Could anyone help me out with the part #? Also, I forgot to label a couple of things under the battery tray. There's a black vac line with a rubber elbow on it that runs under the airbox(right next to another black cable, maybe the hood cable?). Is this the line that gets plugged into the cruise control? There's also another hose with a white tip that I labeled as connecting to the battery tray. Is this the cruise control hose and does the other vac line go somewhere else? Thanks for any help. Link to comment Share on other sites More sharing options...
mulcy Posted June 16, 2010 Author Report Share Posted June 16, 2010 Edit: figured out the SAS hose part # - 9179279. Still looking for help on the vac lines/hoses under the battery tray. Link to comment Share on other sites More sharing options...
mulcy Posted June 16, 2010 Author Report Share Posted June 16, 2010 Added some pics. These are the two lines - which one goes to the cruise control? Here's another pic of the line with the elbow showing how it's routed. Also, one more thing - I also need to figure out what the part # is for this plastic T that connects a vac line to the fuel lines. It's on the timing belt side of the engine right by the bottom of the firewall (where the fuel lines run up from). Anyone know? Link to comment Share on other sites More sharing options...
