Guest james Posted June 20, 2010 Report Share Posted June 20, 2010 my car will lose power and at times will shut off while going down the road. changed fuel pump, still same problem Link to comment Share on other sites More sharing options...
Amart Posted June 21, 2010 Report Share Posted June 21, 2010 I just had a similar problem. I ended up replacing my ECM. It was crazy expensive, but it fixed my issues. If you have an ETM than that also could be an issue. Link to comment Share on other sites More sharing options...
Jaxx Posted June 21, 2010 Report Share Posted June 21, 2010 my car will lose power and at times will shut off while going down the road. changed fuel pump, still same problem can you expand on the problems? does it die instantly simply lose power and then die? does it happen after going full throttle or anything? WHAT CAR ARE YOU DRIVING??? Please give as much information as possible so we can help you out! Link to comment Share on other sites More sharing options...
