f1fanoly Posted June 22, 2010 Report Share Posted June 22, 2010 From what i've heard my '97 855 glt a/t has motronic 4.4,all other 850's use 4.3.'98 x70's run motronic 4.4.From what I understand.You all say if I put '98 ecu in my '97 it will fry the a/c.What i'm doing is replacing old motor(bent valves) with a '98 T5 engine.Already have everything and in the middle of the swap.Question is,why cant I run '98 T5 ecu in my already equipped 4.4 car?I talked to IPD about having my '97 ecu tuned for '98 T5 and there answers were reallv vague and not very confidence inspiring.Is the fried a/c issue between the year of the car or 4.3 vs 4.4?Or is this a mystery question no ones going to be able to answer? Link to comment Share on other sites More sharing options...
9883 Posted June 22, 2010 Report Share Posted June 22, 2010 I'm still not 100% sure if 97GLT is 4.4 or 4.3. I have seen two documents published by Volvo which are contradicting and the 97 T5 is a 4.3. Link to comment Share on other sites More sharing options...
DVolvoguy850T5 Posted June 23, 2010 Report Share Posted June 23, 2010 I'm still not 100% sure if 97GLT is 4.4 or 4.3. I have seen two documents published by Volvo which are contradicting and the 97 T5 is a 4.3. Hanse manual states that 97 is 4.3 Motronic. (my 97 T5 is 4.3) Link to comment Share on other sites More sharing options...
f1fanoly Posted June 23, 2010 Author Report Share Posted June 23, 2010 Hanse manual states that 97 is 4.3 Motronic. (my 97 T5 is 4.3) I've been told on here the '97 GLT is 4.4 and thats why I cant use a '97 T5 or R ecu because they're 4.3.Thats why I was wondering about the '98 T5,if its 4.4 and my '97 GLT is 4.4,can I use a '98 T5 ecu with my new motor for max benefit of the bigger turbo and injectors? Link to comment Share on other sites More sharing options...
Jaxx Posted June 23, 2010 Report Share Posted June 23, 2010 98 was 4.4. better be sure about both though before you fuck up your ac controls Link to comment Share on other sites More sharing options...
f1fanoly Posted June 23, 2010 Author Report Share Posted June 23, 2010 98 was 4.4. better be sure about both though before you monkey up your ac controls If my '97 is in fact 4.3 and not 4.4,I should be able to swap a '97 T5 or R ecu in with no problem,passed on a R ecu for $100 when I bought my engine because I was told my glt was 4.4.Is there any way to find out for sure?If I called the dealer,would they be able to tell me? Link to comment Share on other sites More sharing options...
cheapwagon Posted June 23, 2010 Report Share Posted June 23, 2010 SAS=4.4 Link to comment Share on other sites More sharing options...
f1fanoly Posted June 23, 2010 Author Report Share Posted June 23, 2010 SAS=4.4 Ok,so I have SAS,that means 4.4?Can I run '98 T5 ecu then? Link to comment Share on other sites More sharing options...
Matt01 Posted June 23, 2010 Report Share Posted June 23, 2010 WOW.. i am looking for this exact answer too.. the way i understand it is.. any b5254T engine from 97 has 4.4. such as the GLT's and the AWD.. once i can figure out a way to remove that metal strap around the ECU box, ill confirm it. Link to comment Share on other sites More sharing options...
f1fanoly Posted June 23, 2010 Author Report Share Posted June 23, 2010 WOW.. i am looking for this exact answer too.. the way i understand it is.. any b5254T engine from 97 has 4.4. such as the GLT's and the AWD.. once i can figure out a way to remove that metal strap around the ECU box, ill confirm it. I think the "strap around the ecu box" is the locking lever itself,lift up on it and it rotates up and the ecu lifts out.Is that going to tell you anything though?Are you investigating the possibilities of a '98 ecu also? Link to comment Share on other sites More sharing options...
cheapwagon Posted June 23, 2010 Report Share Posted June 23, 2010 WOW.. i am looking for this exact answer too.. the way i understand it is.. any b5254T engine from 97 has 4.4. such as the GLT's and the AWD.. once i can figure out a way to remove that metal strap around the ECU box, ill confirm it. How will the ECU confirm this for you? They don't say 4.4 or 4.3 on them if that is what you are hoping for. The bottom line to all this confuison is that I doubt anyone has done this swap to a 97 GLT. They may have done 98's but both the T5 and GLT are 4.4 for that year. I would say just do the motor swap and not worry about a HPT ECU right now. Or get a 4.3 HPT ECU since we all know that it won't fry the A/C in a 97 and see what happens. Link to comment Share on other sites More sharing options...
Mesoam Posted June 23, 2010 Report Share Posted June 23, 2010 96/7 N/A's had SAS, wasn't 4.4 I would vote your 97 is a 4.3, most likely 4.4 euro spec being their model years are out a year ahead of ours (hence 1992 850's there) SAS=4.4 Link to comment Share on other sites More sharing options...
f1fanoly Posted June 23, 2010 Author Report Share Posted June 23, 2010 96/7 N/A's had SAS, wasn't 4.4 I would vote your 97 is a 4.3, most likely 4.4 euro spec being their model years are out a year ahead of ours (hence 1992 850's there) Just got off the phone with the local dealer,the parts guy was super cool,he has several 850's in his family and does lots of his own work.He cross referenced and verified that my GLT is 4.3,as is R,and R has AIS for '97,so a '97 R ecu should be a simple plug in and go,maximizing the potential of the '98 T5 motor im installing. Link to comment Share on other sites More sharing options...
Matt01 Posted June 24, 2010 Report Share Posted June 24, 2010 I think the "strap around the ecu box" is the locking lever itself,lift up on it and it rotates up and the ecu lifts out.Is that going to tell you anything though?Are you investigating the possibilities of a '98 ecu also? no theres actually a metal strap over the cover of box yes i have a guy that has a 1998 v70 R ECU that i want. How will the ECU confirm this for you? They don't say 4.4 or 4.3 on them if that is what you are hoping for. The bottom line to all this confuison is that I doubt anyone has done this swap to a 97 GLT. They may have done 98's but both the T5 and GLT are 4.4 for that year. I would say just do the motor swap and not worry about a HPT ECU right now. Or get a 4.3 HPT ECU since we all know that it won't fry the A/C in a 97 and see what happens. well that craps on my plan. chances are getting slim that my AWD has 4.4. Link to comment Share on other sites More sharing options...
f1fanoly Posted June 24, 2010 Author Report Share Posted June 24, 2010 no theres actually a metal strap over the cover of box yes i have a guy that has a 1998 v70 R ECU that i want. well that craps on my plan. chances are getting slim that my AWD has 4.4. I've not seen that strap on any other 850,kinda wierd.Maybe you can call your dealer and see what they can tell you.If not 4.4,then why not a '97 R ecu,theyre available. Link to comment Share on other sites More sharing options...
