Matt854T5 Posted June 27, 2010 Report Share Posted June 27, 2010 Just put in A new radiator. Let it idle for ten min and water would intermittently back up into the reservoir and was boiling then it would go away and was fine and it keeps doing this and engine temp stayed normal. Any ideas? sticky thermostat? I suspected possible head gasket did compression check and got 130 across the board on all cylinders. Link to comment Share on other sites More sharing options...
cgally Posted June 27, 2010 Report Share Posted June 27, 2010 Did you flush radiator before install? Symptons sound like T-stat. Link to comment Share on other sites More sharing options...
Matt854T5 Posted June 27, 2010 Author Report Share Posted June 27, 2010 No I didn't. you still think it would be thermostat even though it didn't overheat? Link to comment Share on other sites More sharing options...
cgally Posted June 27, 2010 Report Share Posted June 27, 2010 Possibly, there could be some debris in the rad. Try flushing the system. I'm assuming that your cooling fan cycled on and off while you idled the car for 10 mins. As for T stats. How old is it? Personally, I replaced mine as part of stage zero. Link to comment Share on other sites More sharing options...
Matt854T5 Posted June 27, 2010 Author Report Share Posted June 27, 2010 Fan was cycling yes. ehh think I replaced the thermostat about 3 years ago. Link to comment Share on other sites More sharing options...
87volvo740t Posted June 28, 2010 Report Share Posted June 28, 2010 There is still air in the system, the way i do it is, fill with about 2lts of water/ coolant mix, run the car with the heater on and the cap off, and slowly add water to the max mark, stop adding water when i reaches the max mark and stays there. you will notice the water slowly climbing to the top of the bottle as the car runs, once it is about 1cm below coming out switch the car off, and it should fall and possibly empty the tank, just refill, and repeat till there is no more fuild drop, and you system will be bleed. Hope this helps, 850's are real pita to bleed properly, but i found this technique to work best. Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted June 28, 2010 Report Share Posted June 28, 2010 What he ^^^^^ said! Link to comment Share on other sites More sharing options...
