mattk42589 Posted June 28, 2010 Report Share Posted June 28, 2010 so i recently purchased an amp out of a 1998 V70 R, part number 9432029, and wanted to know what the power rating is on it. is this the 4x50 watt amp? because I know there is another amp for the s70, part number 6816302 (that mounts behind the radio) that is a 4x50 watt amp, so is the amp i have the 4x100 watt? also, I purchased this amp without the necessary cable, does anyone have one? Link to comment Share on other sites More sharing options...
jschaefer7406 Posted June 28, 2010 Report Share Posted June 28, 2010 Hello, That is the newer 4X50 watt amp (mounts under the RF seat). As you mentioned, there was also a 4X50 watt amp that was found in the later 850's (mounted behind the radio). The harness for the amp you have is nearly impossible to find separately. It is still available new, but is over $150 itself. Anyway, good luck. Hope this helps, Joe Link to comment Share on other sites More sharing options...
MiniA Posted June 28, 2010 Report Share Posted June 28, 2010 good luck with ur search. Link to comment Share on other sites More sharing options...
