mulcy Posted July 3, 2010 Report Share Posted July 3, 2010 Hi All, I'm having some trouble with my 98T5M after an engine swap. The engine cranks and builds oil pressure. Fuel pressure is also good but it won't start. My best guess is that it has something to do with the ignition system. Is it possible to misalign the distributor rotor? I changed the rear intake cam seal on the new motor and had to remove the plate that the distributor rotor mounts to (in order to get to the seal). The plate is only held on by one bolt and I didn't see any markings to help align it with the intake cam. Does the alignment not matter? If it does matter how do I align it? Would appreciate any other suggestions on diagnosing the no start problem also. Thanks! Link to comment Share on other sites More sharing options...
mdlimy Posted July 3, 2010 Report Share Posted July 3, 2010 are you getting spark at all? Link to comment Share on other sites More sharing options...
mulcy Posted July 3, 2010 Author Report Share Posted July 3, 2010 are you getting spark at all? Not sure. Is there an easy way to check? Link to comment Share on other sites More sharing options...
Turconator Posted July 3, 2010 Report Share Posted July 3, 2010 Spark tester? Link to comment Share on other sites More sharing options...
AverageVolvo Posted July 3, 2010 Report Share Posted July 3, 2010 Lol, Stick an old spark plug in the wire and ground it and look for spark. You can even stick a screw driver in the wire plug And if ya don't have someone to crank while you look for spark, you can jump the starter. Link to comment Share on other sites More sharing options...
mulcy Posted July 3, 2010 Author Report Share Posted July 3, 2010 alright, spark is good. Tested all 5 wires by putting a plug in them and watching them spark. Link to comment Share on other sites More sharing options...
yangotang Posted July 4, 2010 Report Share Posted July 4, 2010 did you connect your crank position sensor? Link to comment Share on other sites More sharing options...
mulcy Posted July 4, 2010 Author Report Share Posted July 4, 2010 Alright got her started. The distributor was misaligned after all. The plate that the rotor mounts to is supposed to have two prongs that fit into the slot in the intake cam. Mine were completely worn off for some reason (on the 'new' junkyard engine with 94k). I used the plate from the old engine, lined things up and it started right away. Lots of valve train noise and some smoke coming from back by the turbo... hopefully everything's ok. ABS and Tracs lights are also on but that should be fairly easy to diagnose. Link to comment Share on other sites More sharing options...
