FAST850R Posted July 6, 2010 Report Share Posted July 6, 2010 Hi, I've had this code P0715, which is vehicle speedometer sensor. I believe Volvo has 2 different type of sensors on the transmission. I replaced the one top of the transmission, right below the intake pipe. It didn't fix the problem. Now I have to tackle the other sensor, I believe it's below the battery tray. Does anyone know what to call this sensor, and where to order the part, and how to replace it? The one that I replaced was easy. Just replacing the onld one to new one....but the other one looks more complicated. If anyone can help me to replace the sensor, that would be great. My car is 1996 850r with 141k miles. Thank you. Link to comment Share on other sites More sharing options...
FAST850R Posted July 7, 2010 Author Report Share Posted July 7, 2010 Nobody? I know somebody here knows what I am talking about..... Link to comment Share on other sites More sharing options...
mike-dbf Posted July 7, 2010 Report Share Posted July 7, 2010 Nobody? I know somebody here knows what I am talking about..... it's called a transmission speed sensor,it's located under the air filter assemble and is held down by 1 screw a torx#27.i've seen them priced for $42 @ partsgeek or if there is a pick-a-part or ecology it should be less than $10-if you get it at ecology or p-a-p you can atleast rehearse working on it without worrying about breaking any parts. as far as the wiring,i just cut them and spliced it on the car. Link to comment Share on other sites More sharing options...
FAST850R Posted July 7, 2010 Author Report Share Posted July 7, 2010 it's called a transmission speed sensor,it's located under the air filter assemble and is held down by 1 screw a torx#27.i've seen them priced for $42 @ partsgeek or if there is a pick-a-part or ecology it should be less than $10-if you get it at ecology or p-a-p you can atleast rehearse working on it without worrying about breaking any parts. as far as the wiring,i just cut them and spliced it on the car. Thank you for the reply. If you look at this pdf file, it called RPM sensor(#5 in the picture). I ordered the part, and I tried to replace it by removing air filter box, and battery tray. However, the part looked different from the picture so I couldn't replaced it... Here is the picture of the sensor that I am talking about.... This doesn't look like automatic speed sensor or vehicle speed sensor... Link to comment Share on other sites More sharing options...
fastwagonhawaii Posted July 7, 2010 Report Share Posted July 7, 2010 Thank you for the reply. If you look at this pdf file, it called RPM sensor(#5 in the picture). I ordered the part, and I tried to replace it by removing air filter box, and battery tray. However, the part looked different from the picture so I couldn't replaced it... Here is the picture of the sensor that I am talking about.... This doesn't look like automatic speed sensor or vehicle speed sensor... I might be a newb here but i also have a 96 850 turbo, and my speedo is controlled by the abs sensor. does your abs light come on also? I might be way off but just checking. I might be a newb here but i also have a 96 850 turbo, and my speedo is controlled by the abs sensor. does your abs light come on also? I might be way off but just checking. and the sensor under the air intake is the rpm sensor on the trans. Link to comment Share on other sites More sharing options...
FAST850R Posted July 7, 2010 Author Report Share Posted July 7, 2010 I might be a newb here but i also have a 96 850 turbo, and my speedo is controlled by the abs sensor. does your abs light come on also? I might be way off but just checking. and the sensor under the air intake is the rpm sensor on the trans. Thank you for the reply. I just now replaced the ABS module, but I still get the transmission up arrow light and CEL. Yeah, I thought VSS is controlled by abs on our cars so I hoped that replacing the module would fix it, but no. I also took it to a shop, and a mechanic told me it's one of the sensors on the tranny. I replaced one, but it didn't fix, so I am about to replace the other one..... Like I said, if you look at the picture that I attached, the part looks different from the rpm sensor you can find on online....I am confused. You can clearly see that the gray wire is a lot longer than rpm sensors. I kind of remember it was different look when I tried to replace it....I should have taken pictures... The rpm sensor that I got from online has very short gray wire with a plug. The sensor that attached on the tranny not only looked different, but also the wire was very long. Link to comment Share on other sites More sharing options...
fastwagonhawaii Posted July 8, 2010 Report Share Posted July 8, 2010 I might be a newb here but i also have a 96 850 turbo, and my speedo is controlled by the abs sensor. does your abs light come on also? I might be way off but just checking. and the sensor under the air intake is the rpm sensor on the trans. i just looked at parts geek for you. i think i found it. automatic transmission speed sensor looks like the one in the picture. it controls the torque lock of the trans and other transmission functions. they are selling it for 41.43. the only thing is that its for a 93-95. but check it out. partsgeek.comthis is the print out from the page hope this helps: Click to Enlarge 1993-1995 Volvo 850 Automatic Transmission Speed Sensor FAE Retail Price: $58.65 Your Price: $41.33 Quantity: Part Number: 843-01058736 Notes: Though Volvo calls this a "Engine Speed Sensor", it is used to control Torque Converter Lockup and other Transmission functions only. Brand: FAE Availability: In Stock Condition: New Shipping Options: Ground, Overnight, 2 Day This Product Fits the Following: Catalog: Replacement 1 Vehicle Transmission • 1993 Volvo 850 Automatic • 1994 Volvo 850 Automatic • 1995 Volvo 850 Automatic Link to comment Share on other sites More sharing options...
FAST850R Posted July 8, 2010 Author Report Share Posted July 8, 2010 i just looked at parts geek for you. i think i found it. automatic transmission speed sensor looks like the one in the picture. it controls the torque lock of the trans and other transmission functions. they are selling it for 41.43. the only thing is that its for a 93-95. but check it out. partsgeek.comthis is the print out from the page hope this helps: Click to Enlarge 1993-1995 Volvo 850 Automatic Transmission Speed Sensor FAE Retail Price: $58.65 Your Price: $41.33 Quantity: Part Number: 843-01058736 Notes: Though Volvo calls this a "Engine Speed Sensor", it is used to control Torque Converter Lockup and other Transmission functions only. Brand: FAE Availability: In Stock Condition: New Shipping Options: Ground, Overnight, 2 Day This Product Fits the Following: Catalog: Replacement 1 Vehicle Transmission • 1993 Volvo 850 Automatic • 1994 Volvo 850 Automatic • 1995 Volvo 850 Automatic Thank you for the reply. Hum....so even my car is 96, maybe the transmission was built in 95??? Is there anyway to check whether mine is 95 or 96? I will check the partgeek.com to see whether it's the same part or not. Link to comment Share on other sites More sharing options...
fastwagonhawaii Posted July 8, 2010 Report Share Posted July 8, 2010 Thank you for the reply. Hum....so even my car is 96, maybe the transmission was built in 95??? Is there anyway to check whether mine is 95 or 96? I will check the partgeek.com to see whether it's the same part or not. I wish i knew. I will be able to check soon, I am going to be replacing my pcv valve and will be removing a lot of stuff so i will be able to take a look in my car for the same part. I guess if it doesn't you will have your answer. sorry could not help more. some else chime in on this. Link to comment Share on other sites More sharing options...
FAST850R Posted July 8, 2010 Author Report Share Posted July 8, 2010 I wish i knew. I will be able to check soon, I am going to be replacing my pcv valve and will be removing a lot of stuff so i will be able to take a look in my car for the same part. I guess if it doesn't you will have your answer. sorry could not help more. some else chime in on this. Thank you so much for all your replies. My car runs fine so it's not an emergency situation I just don't want to see the CEL and up arrow flashing all the time while I am driving. I have to tackle other problems for now, so if you can check it while you are replacing pcv system, that would be great. If I remove the battery tray and air filter tray again, I will take pictures and post here...but I am sure it looked exactly same as the picture above.. Link to comment Share on other sites More sharing options...
Ozark Lee Posted July 9, 2010 Report Share Posted July 9, 2010 The vehicle speed sensor on my '94 is on the passenger's side of the transaxle, just above the axle vertically. I haven't looked for it on my '96s or the S70 so I don't know if it was changed along with the speedometer setup after '95. You need to get under the car to get to it. ...Lee Link to comment Share on other sites More sharing options...
FAST850R Posted July 10, 2010 Author Report Share Posted July 10, 2010 The vehicle speed sensor on my '94 is on the passenger's side of the transaxle, just above the axle vertically. I haven't looked for it on my '96s or the S70 so I don't know if it was changed along with the speedometer setup after '95. You need to get under the car to get to it. ...Lee I believe 96 is different. VSS is top of the transmission right below air intake pipe(ptc). The RPM sensor is right below air filter box. I need to remove a battery tray and air filter box to access and remove it. It just look different from 96 rpm sensor that I ordered. Link to comment Share on other sites More sharing options...
FAST850R Posted July 10, 2010 Author Report Share Posted July 10, 2010 Ok, I found this page Somebody is selling transmission harness on ebay. If you look carefully, there is the rpm sensor, but the end of wire connected to the socekt.... It totally looks different from this, which I have ordered before. Link to comment Share on other sites More sharing options...
JordanW Posted July 10, 2010 Report Share Posted July 10, 2010 Right, they are different. One is for output speed (the one with the connector) The input speed sensor is part of the transmission connector. You can pull the connector apart and seperate the part you need. Have you checked the sensors out with a DVOM? Link to comment Share on other sites More sharing options...
JordanW Posted July 10, 2010 Report Share Posted July 10, 2010 Right, they are different. One is for output speed (the one with the connector) The input speed sensor is part of the transmission connector. You can pull the connector apart and seperate the part you need. Have you checked the sensors out with a DVOM? Sorry, that made no sense. Output speed sensor/VSS is by itself (the one on your partsgeek.com link). Input speed sensor/trans RPM sensor is the one from your ebay link. You can take apart the transmission connector to get just the input/rpm sensor. The pdf link up above has the ohm/resistence specs for you to check them out. Link to comment Share on other sites More sharing options...
