Grocery_Getter_96 Posted July 20, 2010 Report Share Posted July 20, 2010 Hey Guys, I ordered a Double Din DVD Player and I wired it up using a harness from Best Buy Plugged it in and i dont know if i wired it wrong or if i have a faulty component. I plug it in and it beeps at me and gives me a Grey screen saying Back view...The Player has a option for a back up camera but when i try to go to a different Mode or Setting It wont Let me...I have a d2206 Enonon DVD player. And A 200 V70R is the wiring different in my car? I have put one in my 855 a few years back without any trouble and my R seems to have more wires than my 855 did... i dont know if some of its security and one wire is the AMP wire..it looks like it has 2 antenna plugins and has 2 cannon plugs along with the two ports with speaker wire..ive looked for a Diagram but couldnt find one in the owners manual or find one worthy enough on the internet...can anyone help me out? A diagram of what each wire is would be great! or any advice...I probably should of went with a Pioneer DVD player or something but i liked the price and what it could do for the money so i figured i would give the Enonon a try since thats what i put in the 855 a couple years ago.. Thanks. Link to comment Share on other sites More sharing options...
bdimag Posted July 20, 2010 Report Share Posted July 20, 2010 did you use a wiring harness adapter? or did you cut the plug and try matching colors? Basically there should be a wire going to the HU which tells it that you're in reverse, and it sounds like you've hooked that up by mistake to a constant signal... Link to comment Share on other sites More sharing options...
TRACStar Posted July 20, 2010 Report Share Posted July 20, 2010 it sounds like you've hooked that up by mistake to a constant signal... That gets my vote also Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 20, 2010 Author Report Share Posted July 20, 2010 Anyone Know What color Wire That is? I bought a harness so i didnt cut any wires on the Volvo Harness Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 20, 2010 Author Report Share Posted July 20, 2010 On the Harness Package it said Years 93 and up do i have the wrong harness?? Link to comment Share on other sites More sharing options...
bdimag Posted July 21, 2010 Report Share Posted July 21, 2010 it's a wire on the radio side of the wire harness... it's in a wiring diagram for your radio, not for your car take it out and attach the very basics -- red yellow black -- see what it does. Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 21, 2010 Author Report Share Posted July 21, 2010 i checked all the wiring and i couldnt find a wire for the camera and all the wires for speakers are correct it has a rca cable for the camera thats seperate... i will have to hook up the basic wires and get back to you.. thanks! Link to comment Share on other sites More sharing options...
bdimag Posted July 21, 2010 Report Share Posted July 21, 2010 maybe it's more like -- a reverse signal turns on the camera and any signal coming over that RCA switches to back-up mode... is the empty rca plug covered? now that i'm home let me find some wiring diagrams too... Link to comment Share on other sites More sharing options...
bdimag Posted July 21, 2010 Report Share Posted July 21, 2010 this was described as 98 v70 Car Radio Battery Constant 12v+ Wire: Green/Brown Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Blue/White Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Red/White Left Front Speaker Negative Wire (-): Yellow/White Right Front Speaker Positive Wire (+): Yellow/Gray Right Front Speaker Negative Wire (-): Gray Car Audio Rear Speakers Size: 5 1/4″ Car Audio Rear Speakers Location: Doors Left Rear Speaker Positive Wire (+): Brown/White Left Rear Speaker Negative Wire (-): Brown/Black Right Rear Speaker Positive Wire (+): Pink/Black Right Rear Speaker Negative Wire (-): Pink/Whiteand.... http://www.eonon.com/down_pdf.aspx?name=D2206_EN.pdf the orange wire... make sure it is disconnected. that's usually the standard for "illumination" but in this case its where you feed +12 while in reverse. Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 21, 2010 Author Report Share Posted July 21, 2010 Thanks! Ill try it tonight and let you know! i had the orange wire connected so hopefully thats my issue Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 21, 2010 Author Report Share Posted July 21, 2010 unplugged the orange wire and now the screen doesnt even light up....starting to get frustrated...i guess i better start with the basic wires tomorrow after work....any thoughts? Link to comment Share on other sites More sharing options...
bdimag Posted July 21, 2010 Report Share Posted July 21, 2010 make sure the harness is matching the right volvo colors... i sent you PM if you haven't seen it... Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 21, 2010 Author Report Share Posted July 21, 2010 i got your pm ill try it when i get out of work ive replaced plenty of headunits i dont know why i am having so much trouble with this..... Link to comment Share on other sites More sharing options...
Grocery_Getter_96 Posted July 22, 2010 Author Report Share Posted July 22, 2010 the 98 color code chart you posted doesnt match the colors of my harness i bought from best buy Would it work if i tapped the orange for illumination to the power wire? because the screen does not appear ever since i disconnected the orange wire..I have checked a few times and it seems like everything is hooked up right..by looking at the charts. But I wasnt clear on how to read the PDFs you PMed me.. Link to comment Share on other sites More sharing options...
TRACStar Posted July 22, 2010 Report Share Posted July 22, 2010 The harness you bought isn't supposed to match the factory harness colors. Its color coded to match the harness coming out of the head unit. Tie the brown wire coming off the HU with the black ground wire also. There is no illumination wire listed in the diagram above but its possible that its just setup to be always on. Link to comment Share on other sites More sharing options...
