ACiancio Posted July 25, 2010 Report Share Posted July 25, 2010 Ok a little bit of info to start off. I have a company truck and my wife just got a new car so my 850 sits most of the time and I use it when the wife is away and I need to run somewere. Now to my problem, A few weeks back I took her out to get a few things and I heard a small ticking noise after a while. when I checked the dipstik was dry, It was close to needing an oil change so I just picked up some oil and a filter while I was out. what really has me worried/confused is I only got 2.5qts out when I changed the oil. now the car doesnt smoke and doesnt have any major oil leaks (and I know this because it sits in the same spot for weeks at a time) so where did all my oil go? Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted July 25, 2010 Report Share Posted July 25, 2010 Ok a little bit of info to start off. I have a company truck and my wife just got a new car so my 850 sits most of the time and I use it when the wife is away and I need to run somewere. Now to my problem, A few weeks back I took her out to get a few things and I heard a small ticking noise after a while. when I checked the dipstik was dry, It was close to needing an oil change so I just picked up some oil and a filter while I was out. what really has me worried/confused is I only got 2.5qts out when I changed the oil. now the car doesnt smoke and doesnt have any major oil leaks (and I know this because it sits in the same spot for weeks at a time) so where did all my oil go? have you been using regular, high mileage, then recently switched to synthetic? when i did this i only drained 2.5 qts with synthetic in but no leaks on ground, i recently switched back to high mileage. Link to comment Share on other sites More sharing options...
ACiancio Posted July 26, 2010 Author Report Share Posted July 26, 2010 Probably, I have only used mobil-1 in it but this is only my second oil change and i don't know what the owner before me used. this time I used mobil-1 High mileage, we will see how it does Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted July 26, 2010 Report Share Posted July 26, 2010 Probably, I have only used mobil-1 in it but this is only my second oil change and i don't know what the owner before me used. this time I used mobil-1 High mileage, we will see how it does yea i guess it just leaks into the engine or something, im pretty sure synthetic has smaller molecules and can get in places easier. Link to comment Share on other sites More sharing options...
ACiancio Posted July 26, 2010 Author Report Share Posted July 26, 2010 that still doesn't fully make since. if the oil was leaking into the cylinders you would get that lovely purple cloud at the tailpipe. and yes I do have a little soot buildup at my tailpipe the exhaust doesn't smell of oil nor do I have any purple smoke, at idle or when you floor it. so that still leaves the question "where does it go" Link to comment Share on other sites More sharing options...
850T5M Posted July 26, 2010 Report Share Posted July 26, 2010 Have an alarm on the car? Someone might have stolen your oil!! All jokes aside, the oil was either burned or is leaking... Logically if its not leaking oil, then it must be burning it slowly. Maybe you never noticed before recently. Link to comment Share on other sites More sharing options...
vjaneczko Posted July 26, 2010 Report Share Posted July 26, 2010 Do you have your skid plate and air guide? Maybe there's a leak that they're hiding. Link to comment Share on other sites More sharing options...
