Mojav Posted September 29, 2010 Report Share Posted September 29, 2010 Nice pictures of your install. I have a 1998 V70 GLT wagon with a stock sc-816 which i plan to replace with a Pioneer P3200bt. I'm curious about your bezel and fit kit. It looks tight and clean. What kit is this ? Is it a Metra or Scosche? My second interest is to be able to rever the install back to the sc-816 and mount the P3200bt elsewhere if and when i upgrade my wagon. Is your install planned with this in mind ? thanks, Mojav Link to comment Share on other sites More sharing options...
dimka18 Posted October 3, 2010 Report Share Posted October 3, 2010 hey, where did u get the insert for the double din? the plastic pieces around it? im looking to install a double din in my 850 but dont know where to get the insert.. thank you Link to comment Share on other sites More sharing options...
andyb5 Posted October 4, 2010 Report Share Posted October 4, 2010 Nice pictures of your install. I have a 1998 V70 GLT wagon with a stock sc-816 which i plan to replace with a Pioneer P3200bt. I'm curious about your bezel and fit kit. It looks tight and clean. What kit is this ? Is it a Metra or Scosche? My second interest is to be able to rever the install back to the sc-816 and mount the P3200bt elsewhere if and when i upgrade my wagon. Is your install planned with this in mind ? thanks, Mojav Here's my Pioneer AVH-P4000DVD in my 98 V70: To install a double Din unit in the stock opening, you'll need to remove the 2 plastic mounting tabs on the inside of the dash opening. If your unit doesn't come with a metal dash mount (aka "sleeve" or "pocket"), you will need to buy one. I used a GM mount for mine. I attached the metal dash mount to the Pioneer, placed it in the dash opening, then used the mounting tabs on the metal mount to lock the unit in place. I made the trim bezel with a piece of ABS sheet I had laying around, and fastened it with 3M foam double sided tape. Hope that helps Link to comment Share on other sites More sharing options...
