boxpin Posted August 6, 2010 Author Report Share Posted August 6, 2010 I just bought the Aquamist System 1S Link to comment Share on other sites More sharing options...
sconeman Posted August 7, 2010 Report Share Posted August 7, 2010 I just bought the Aquamist System 1S I have Kevin's tweaked stage 3 tune on the V70R and yes it was tuned for aquamist at 10psi fyi. I have not installed mine yet it's sitting in a box will go on when I put the NA intake mani and NA TB on. pulls pretty damn hard but I get worried in the high RPMS, tuned to 7200 I believe. Alc spray should make things much safer and consistently faster/ Link to comment Share on other sites More sharing options...
aggarcia Posted August 7, 2010 Report Share Posted August 7, 2010 The Stage III should have better AFR and is tuned for the 18T vs the Stage I tuned for the 15G. I would think Lucky might have more insight into the differences of Stage I vs III. I like the idea of the TT, but they state for off road use only. I am not sure the ramifications of running on street and passing local emission testing. Cost wise especially if planning a manual conversion and other upgrades, almost as good as a stand alone system without other modifications required to make stand alone system work properly. AG Link to comment Share on other sites More sharing options...
AverageVolvo Posted August 7, 2010 Report Share Posted August 7, 2010 Off road use is a liability disclaimer. Passes smog for auto tunes NP. I live in Ca If you convert to Manual You will not be able to pass smog. The Manual tunes do not have Obd 2 function so 96+ fail. I failed Nox Ho2 visual and Obd2 Basically everything. Link to comment Share on other sites More sharing options...
the commissar! Posted August 8, 2010 Report Share Posted August 8, 2010 No emissions testing where I am but if there were I work for the air pollution control agency Link to comment Share on other sites More sharing options...
