Hellas850 T-5 Posted August 18, 2010 Report Share Posted August 18, 2010 Hello guys,It might be a very common problem,sorry for this For about a month now,the car makes very strange things,at the beginning the problem was appeared only at idle,while I was driving and had to stop to a traffic light let's say,the idle was staying at 1000 rpm,and after a while it was reving until 1400 rpm,and staying there for a while,now a week ago it does the same but also if I will leave to idle for about 5 minutes the revs drop to a level that you think that the engine will shut off and then comes back to normal level.And under boost sometimes it makes like cut off-misfire, I have checked and changed all the vacuum hoses with silicone hoses,I also changed the MAF sensor,and the idle valve,the other hoses are all of them SAMCO.spark plugs have 10000 km on them,fuel filter the same. Any thoughts?It will make me crazy. Link to comment Share on other sites More sharing options...
V1CUT Posted August 18, 2010 Report Share Posted August 18, 2010 ECT sensor Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 18, 2010 Author Report Share Posted August 18, 2010 ECT sensor Tomorrow I will buy a new one,thanks a lot,I will post for the feedback. Link to comment Share on other sites More sharing options...
custom R Posted August 18, 2010 Report Share Posted August 18, 2010 I understand your frustration first hand. Other possibilities would be: PCV system, weak fuel pump, crank & or TPS. I hope this info helps, and lots of luck. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 19, 2010 Author Report Share Posted August 19, 2010 I understand your frustration first hand. Other possibilities would be: PCV system, weak fuel pump, crank & or TPS. I hope this info helps, and lots of luck. thanks for your reply,the OEM PCV system is not operating,I have a catch can,fuel pump walbro,I will check it again,and I will check crank sensor,TPS was replaced in the past without having problem,only as preventive action. Link to comment Share on other sites More sharing options...
the commissar! Posted August 19, 2010 Report Share Posted August 19, 2010 How about idle air control... Link to comment Share on other sites More sharing options...
V1CUT Posted August 19, 2010 Report Share Posted August 19, 2010 "I have checked and changed all the vacuum hoses with silicone hoses,I also changed the MAF sensor,and the idle valve,the other hoses are all of them SAMCO.spark plugs have 10000 km on them,fuel filter the same." Says he's changed it... Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 19, 2010 Author Report Share Posted August 19, 2010 Guys earlier this afternoon,as the symptons were the same,for my luck the λ bulb appeared..... guess what 5-1-4 or RPM Sensor.....I will change it and see the results. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 27, 2010 Author Report Share Posted August 27, 2010 Ηello guys,I changed the RPM sensor,I had one from an engine that was ok-I think-and for one day was ok,today the same symptons again,and I noticed some other things,when the A/C is on the symptons are harder.And I noticed a difference in the performance,the car seems to be a to have like turbo lag.Recently I changed the turbo from 15G to brand new 19T,at the begining it was fun to drive. Link to comment Share on other sites More sharing options...
custom R Posted August 28, 2010 Report Share Posted August 28, 2010 Are you getting any codes?? Was the timing belt changed recently? If so, check to see if your timing is accurate. If you find out if / what codes the care is throwing, that should point you in the right direction. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 28, 2010 Author Report Share Posted August 28, 2010 Are you getting any codes?? Was the timing belt changed recently? If so, check to see if your timing is accurate. If you find out if / what codes the care is throwing, that should point you in the right direction. No codes now some days ago the rpm sensor code appeared,changed the sensor but now again the same. Link to comment Share on other sites More sharing options...
MyCarIsRed Posted August 28, 2010 Report Share Posted August 28, 2010 fuel pressure? The relays are notorious... Link to comment Share on other sites More sharing options...
98 s70 t5m Posted August 28, 2010 Report Share Posted August 28, 2010 Make sure your plug wires are far away from your RPM sensor leads. I had an occasional misfire after I changed plug wires and it was because my plug wire were too close to the sensor. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 30, 2010 Author Report Share Posted August 30, 2010 Hello again,the thing is not going well,today after refuelling,in a SHELL gas station,after two kilometres,the λ bulb appeared again...... I checked the codes,and now a code for rear knock sensor is there,also another one for the fan and for the A/C pressure sensor,and sorry the in a previous post I made a mistake with the code's number for the rpm sensor.any ideas? Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted September 7, 2010 Author Report Share Posted September 7, 2010 I changed and the ECT sensor and still the same,it appears after driving,when I stop to a traffic light let's say,any other thoughts? Link to comment Share on other sites More sharing options...
