Karl Buchka Posted March 18, 2013 Report Share Posted March 18, 2013 A lot. Everything. No. The DCOE flange needs to be cut in half, then the throttles will be split apart and welded to the flange. The throttles will also need some of the vacuum ports plugged and the inlets need to be turned to mate with the velocity stacks. The throttle outlets will probably need a round in the lathe as well to make port matching easier. The cast manifold is clearly of dubious quality and will probably need to have the faces milled flat. Since the throttles will be split, the fuel rail blank will be machined to fit the new spacing. AN fittings will also get welded on and mounting brackets will also need to be fabricated. Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 18, 2013 Author Report Share Posted March 18, 2013 A lot. Everything. No. The DCOE flange needs to be cut in half, then the throttles will be split apart and welded to the flange. The throttles will also need some of the vacuum ports plugged and the inlets need to be turned to mate with the velocity stacks. The throttle outlets will probably need a round in the lathe as well to make port matching easier. The cast manifold is clearly of dubious quality and will probably need to have the faces milled flat. Since the throttles will be split, the fuel rail blank will be machined to fit the new spacing. AN fittings will also get welded on and mounting brackets will also need to be fabricated.What he said. 1 Quote Link to comment Share on other sites More sharing options...
Johann Posted March 18, 2013 Report Share Posted March 18, 2013 What he said. Why use the cast at all? Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 18, 2013 Author Report Share Posted March 18, 2013 Why use the cast at all? For mocking up purposes it's fine. I may replace it with a higher quality OEM set of manifolds. Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 18, 2013 Author Report Share Posted March 18, 2013 How much work will it take to get it to fit ? What will be modified ? Or are you running intermediate runners to mate up the two parts ? A little more clarity shown here. Quote Link to comment Share on other sites More sharing options...
matt b Posted March 18, 2013 Report Share Posted March 18, 2013 OK, now I see it. Are you planning on running filters on the stacks ? I'm buying some now for some Webers, prior owner of a car was running the velocity stacks wide open. Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 18, 2013 Author Report Share Posted March 18, 2013 OK, now I see it. Are you planning on running filters on the stacks ? I'm buying some now for some Webers, prior owner of a car was running the velocity stacks wide open. Yes Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 24, 2013 Author Report Share Posted March 24, 2013 Rear suspension is complete.Untitled by KeysarPhoto, on FlickrModified weight jack spring cups.Untitled by KeysarPhoto, on Flickrcrappy cell phone pic of how the rear sits now. Just tad lower.Untitled by KeysarPhoto, on Flickr 4 Quote Link to comment Share on other sites More sharing options...
Leo850T5 Posted March 24, 2013 Report Share Posted March 24, 2013 Good taste goes a long way. Very nice! Quote Link to comment Share on other sites More sharing options...
Johann Posted March 24, 2013 Report Share Posted March 24, 2013 Spring not locked at full travel? Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 24, 2013 Author Report Share Posted March 24, 2013 Spring not locked at full travel? No. Need shorter shocks. Quote Link to comment Share on other sites More sharing options...
gdizzle Posted March 24, 2013 Author Report Share Posted March 24, 2013 4 Quote Link to comment Share on other sites More sharing options...
BurgerBob Posted March 24, 2013 Report Share Posted March 24, 2013 9 Quote Link to comment Share on other sites More sharing options...
854TGA+ Posted March 25, 2013 Report Share Posted March 25, 2013 Awesomeness! Old School parked in front of old school? Quote Link to comment Share on other sites More sharing options...
matt b Posted March 25, 2013 Report Share Posted March 25, 2013 I LOL'ed. 1 Quote Link to comment Share on other sites More sharing options...
