Big Will Posted August 22, 2010 Report Share Posted August 22, 2010 Since I switched to a Mac I no longer have access to VADIS and have a quick favor to ask. Would someone mind putting up the print screen of the angle gear for an early 98 AWD car (so the first version of the angle gear) so that I can see the part numbers for all of the seals around the gear. The o-ring under the adjuster nut is still leaking on mine and I need to see which seals to buy while it's convenient. Thank you! Link to comment Share on other sites More sharing options...
Black Betty Posted August 22, 2010 Report Share Posted August 22, 2010 Since I switched to a Mac I no longer have access to VADIS and have a quick favor to ask. Would someone mind putting up the print screen of the angle gear for an early 98 AWD car (so the first version of the angle gear) so that I can see the part numbers for all of the seals around the gear. The o-ring under the adjuster nut is still leaking on mine and I need to see which seals to buy while it's convenient. Thank you! vin? or chassis code for the early 98 awd? Link to comment Share on other sites More sharing options...
heat391 Posted August 23, 2010 Report Share Posted August 23, 2010 You can use boot camp or vm virtual box and run windows...... Other than that, angle gear s70 ch 385747-511803.pdf ange gear S70 FC1;CH 511804- FC.pdf Bill Link to comment Share on other sites More sharing options...
Big Will Posted August 23, 2010 Author Report Share Posted August 23, 2010 Thank you very much for posting those. Link to comment Share on other sites More sharing options...
