Dave 54 Posted August 23, 2010 Report Share Posted August 23, 2010 The radio reception in my wagon blows compared to the wifes sedan! Anyone using anything to help boost the antenna signal? Link to comment Share on other sites More sharing options...
TRACStar Posted August 23, 2010 Report Share Posted August 23, 2010 Has it always been bad? My wagon always had great reception, it picked up stations that I didn't even know existed. :lol: Link to comment Share on other sites More sharing options...
Dave 54 Posted August 24, 2010 Author Report Share Posted August 24, 2010 IDK both wagons i've had so far seem to have a weaker setup then either of the sedans. Well I gotta tear the panel off anyway so I guess i'll snoop around and see if anything stands out of place. If all looks well then i'll probably go with one like this, http://www.crutchfield.com/S-JBDijTtnCFr/p_12044UA60/FM-Signal-Amplifier.html . Should be able to mount it in an extra dash switch spot. :D Link to comment Share on other sites More sharing options...
andyb5 Posted August 24, 2010 Report Share Posted August 24, 2010 The radio reception in my wagon blows compared to the wifes sedan! Anyone using anything to help boost the antenna signal? I'm almost positive the wagons have a small antenna signal booster in the back. I think there was a thread to this effect on SS a while back, and I tried searching, but the thread was lost when they went to the new format. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 24, 2010 Author Report Share Posted August 24, 2010 I'm almost positive the wagons have a small antenna signal booster in the back. I think there was a thread to this effect on SS a while back, and I tried searching, but the thread was lost when they went to the new format. Thanks, perhaps i'll find something loose or missing when I tear the panel off. Link to comment Share on other sites More sharing options...
TRACStar Posted August 24, 2010 Report Share Posted August 24, 2010 Yeah, if something seems out of place see if it can be fixed and improve the signal. If not I can check my wagon and grab the booster or whatever it is for ya if you want it cause mine always had good reception. Link to comment Share on other sites More sharing options...
the commissar! Posted August 26, 2010 Report Share Posted August 26, 2010 Does your 850 have the rear antennas built into the two side glass panels at the cargo area like my V70? If so check that they are plugged in...Cables are under the floor panels and run iirc back the passenger side and fork across to the other side. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 26, 2010 Author Report Share Posted August 26, 2010 Negative, only have it n the DS. Going to be pulling the panel later today to have a look. Link to comment Share on other sites More sharing options...
msestina Posted August 28, 2010 Report Share Posted August 28, 2010 I'm almost positive the wagons have a small antenna signal booster in the back. I think there was a thread to this effect on SS a while back, and I tried searching, but the thread was lost when they went to the new format. That is correct. The wagons have an antenna amp on that side. Make sure it is getting power. Link to comment Share on other sites More sharing options...
MyCarIsRed Posted August 28, 2010 Report Share Posted August 28, 2010 That is correct. The wagons have an antenna amp on that side. Make sure it is getting power. Yeppers. I was not a fan of the volvo tuners, i replaced my hu with a pioneer on stock antenna and the reception is awesome. Do you have HD radio coverage in your area? Invest. Link to comment Share on other sites More sharing options...
850newb Posted September 1, 2010 Report Share Posted September 1, 2010 I picked up a metra universal windsheild interior antenna for $20 at pepboys, a little better reception than the stocker, same plug and simple installation. Link to comment Share on other sites More sharing options...
Dave 54 Posted September 1, 2010 Author Report Share Posted September 1, 2010 Cool, still haven't ripped into to see what's up. Been busy around the house doing renovations. I will keep that in mind just incase things are legit when I investigate further. Link to comment Share on other sites More sharing options...
