Jippi 855 GLT Posted August 26, 2010 Report Share Posted August 26, 2010 2000 v40 parking lights dont work, fuses are good, what can it be? it work for a little bit and then it jus stopped all together. is it a bad CEM? Link to comment Share on other sites More sharing options...
nmikmik Posted August 29, 2010 Report Share Posted August 29, 2010 Not sure if you ever got your question answered. Nor do I know anything about CEM or S40 parking lights. googling CEM returned this possibly useful thread CEM repair If you can trace the parking lights output from the CEM and verify you have +12 on it, you would be able to stop your CEM worries and continue the tracing until you find where the problem lays. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted August 29, 2010 Author Report Share Posted August 29, 2010 yep already came across that, im gonna see what the JY brings, i took it apart to find the 3 light relays bloated. Link to comment Share on other sites More sharing options...
nmikmik Posted August 29, 2010 Report Share Posted August 29, 2010 what do you mean bloated? Are they swelling to the sides or something? If you want to test the relay you just need to supply 12V from the source side directly to the exit side bypassing the coil, pretty much a piece of stripped wire should do. I've done number of trips to the JY just to find relays that I bought are not any better than the one I got. good luck, hey Link to comment Share on other sites More sharing options...
MrWinkey Posted August 31, 2010 Report Share Posted August 31, 2010 Jump the T terminals on the relay block...30 and 87 are standard numbers Link to comment Share on other sites More sharing options...
