Gregg Posted December 18, 2004 Report Share Posted December 18, 2004 I have the S90 antenna switch w/ the harness plugged into the switch and a whole bunch of wires hanging off of it. I want to hook it up to work with my Pioneer head unit (antenna up/down operation, as well as have the switch light up like it's supposed to).I tried searching both in Cosmetic and Audio, but could not find a good write-up with pics of exactly which wires on the back of the switch are used and where they get connected to. Can anyone help please? Accompanying pics would be greatly appreciated. Link to comment Share on other sites More sharing options...
Veneficus Posted December 18, 2004 Report Share Posted December 18, 2004 http://www.volvospeed.com/Repair/radiocon.htmTheres a schematic that Rich posted. All you have to do is run the switch between the antenna line. All that the switch does it send a signal (like a remote line does to an amp) and when that signal is present, the antenna will go up. I'm willing to bet that there are 3-4 wires comming off of it. 2 of them are for attachment to the antenna line and one to two are for illuminating the switch (a positive and a negative...maybe). Also when you do this, if you could take pics, that would be great, we can use this as another write up. ;) Link to comment Share on other sites More sharing options...
spottieottie Posted December 18, 2004 Report Share Posted December 18, 2004 sorry I f'd up I'll try again below Link to comment Share on other sites More sharing options...
spottieottie Posted December 18, 2004 Report Share Posted December 18, 2004 The larger one is the connect for the Volvo harness and the small connect is for the aftermarket HU harness (or volvo radio).Hope this helps Gregg, let me know if you need pics of the wires to the switch, the ones above are not close enough to decifer the wire colors. Hope this helps, peace P.S. This coupled with Rich's schematics should give you a pretty good idea. :) Link to comment Share on other sites More sharing options...
spottieottie Posted December 18, 2004 Report Share Posted December 18, 2004 Allright, It's all fixed now. Sweeet!!!! Link to comment Share on other sites More sharing options...
dancetheman Posted December 18, 2004 Report Share Posted December 18, 2004 what....so how did you do this?i can see which one the wire is an allbut how did you wire it to the switch to get it to go up and down....oh welltime to stick with no fuse for now Link to comment Share on other sites More sharing options...
Gregg Posted December 18, 2004 Author Report Share Posted December 18, 2004 ok, here are my pictures. The first one shows all the wires coming off the back of the antenna swtich.The black wire and pink wire I tapped off of the defroster switch right next to it. The blue & white wire I tapped off the radio harness (right before the large plug that would go into a stock head unit).My problem is the last 2 wires:Where do they go? Do both need to be connected?I tried tapping the blue & yellow wire on the switch into the blue & yellow wire on the radio harness - nothing.I tried tapping the blue & yellow wire on the switch into the blue & white wire on the radio harness - nothing.Please someone help. I want to get this all hooked up and put back together tonight. Thanks. Link to comment Share on other sites More sharing options...
Veneficus Posted December 18, 2004 Report Share Posted December 18, 2004 GuessesWhite/Blue Wire - hu to switchBlue/Orange Wire - switch to antennaOrange/Red - uhhhThe last three wires should be interchangable so switch them around until you find something that works.Did you cut the antenna wire? You have to crimp those two onto opposite ends of the +Antenna line. This is what sends the current to the antenna that makes it go up. Link to comment Share on other sites More sharing options...
AnthonyR Posted December 19, 2004 Report Share Posted December 19, 2004 OK, not sure what wire is which on that switch, however the wire from the radio you want to tap into is the solid blue wire (antenna lead) the blue/white is for amp turn on, and the blue/yellow is mute lead? maybe I dunno, but you want to split the solid blue and wire the switch in Link to comment Share on other sites More sharing options...
PyROZen Posted December 19, 2004 Report Share Posted December 19, 2004 couldn't you just bypass the switch completely and let the HU put the antenna up and down? If my antenna worked i know my HU would lower the antenna whenever it turns off ,I put in a CD, or switch the the disc changer. Link to comment Share on other sites More sharing options...
AnthonyR Posted December 19, 2004 Report Share Posted December 19, 2004 couldn't you just bypass the switch completely and let the HU put the antenna up and down? If my antenna worked i know my HU would lower the antenna whenever it turns off ,I put in a CD, or switch the the disc changer.←Yeah, most HU's will do this automatically, although I've unplugged mine altogether. I only listen to Sirius now. (and woohoo my sirius alpine tuner is in the mail!) Link to comment Share on other sites More sharing options...
Veneficus Posted December 19, 2004 Report Share Posted December 19, 2004 I did this to a friends '94 850 today and the wire that controlled the antenna was a blue wire w/ a white stripe. Link to comment Share on other sites More sharing options...
Gregg Posted December 20, 2004 Author Report Share Posted December 20, 2004 My head unit does not have the feature to put the antenna down while playing CDs.So I need to cut the blue/white wire? Connect the blue/white wire on the switch to the blue/white wire going to the hu? And then connect the blue/yellow wire on the switch to the blue/white wire going to the antenna? Is this correct?What do I do with the red/yellow wire? Link to comment Share on other sites More sharing options...
Veneficus Posted December 20, 2004 Report Share Posted December 20, 2004 My head unit does not have the feature to put the antenna down while playing CDs.So I need to cut the blue/white wire? Connect the blue/white wire on the switch to the blue/white wire going to the hu? And then connect the blue/yellow wire on the switch to the blue/white wire going to the antenna? Is this correct?What do I do with the red/yellow wire?←Yes, your wiring description is correct. And for the red/yellow wire... uh.... dunno. Probably nothing. It might be another wire for lights, I'm not sure. Link to comment Share on other sites More sharing options...
Gregg Posted December 21, 2004 Author Report Share Posted December 21, 2004 Yes, your wiring description is correct. And for the red/yellow wire... uh.... dunno. Probably nothing. It might be another wire for lights, I'm not sure.←Thanks for your help Brian. I got it hooked up tonight the way you confirmed. I did a write-up with pics. Bing already pinned it! :) Link to comment Share on other sites More sharing options...
