michael-s70 Posted August 27, 2010 Report Share Posted August 27, 2010 Recently rebuilt a 95 850 turbo, the car cranks and has fuel pressure but theres no spark....Have swapped in know good crank and cam sensors and a good maf. oil pressure sending unit is not connected due it being damaged during install (will put in a new one tomorrow), And when i turn the key to run position the check engine light does not come on nor does it while cranking. i dont have a code reader for this car at the moment. any pointers? greatly appreciated, thanks Link to comment Share on other sites More sharing options...
Bah Posted August 27, 2010 Report Share Posted August 27, 2010 Recently rebuilt a 95 850 turbo, the car cranks and has fuel pressure but theres no spark....Have swapped in know good crank and cam sensors and a good maf. oil pressure sending unit is not connected due it being damaged during install (will put in a new one tomorrow), And when i turn the key to run position the check engine light does not come on nor does it while cranking. i dont have a code reader for this car at the moment. any pointers? greatly appreciated, thanks Is the coil connected up? Dunno exactly where it goes back to in the harness, but it might be worth investigating to see. I don't believe the Oil Pressure unit affects spark, but i could be wrong. If its a 95 it should have a box in the engine bay, or is that what you meant by no code reader? Link to comment Share on other sites More sharing options...
michael-s70 Posted August 27, 2010 Author Report Share Posted August 27, 2010 Is the coil connected up? Dunno exactly where it goes back to in the harness, but it might be worth investigating to see. I don't believe the Oil Pressure unit affects spark, but i could be wrong. If its a 95 it should have a box in the engine bay, or is that what you meant by no code reader? i will check power and ground to coil today, code reader as in handheld obdII. i willl check for codes with the pin thing. Link to comment Share on other sites More sharing options...
f1fanoly Posted August 27, 2010 Report Share Posted August 27, 2010 i will check power and ground to coil today, code reader as in handheld obdII. i willl check for codes with the pin thing. How about the cam sensor trigger that bolts to the exhaust cam?If its flipped 180deg,no spark/no start condition. Link to comment Share on other sites More sharing options...
michael-s70 Posted August 28, 2010 Author Report Share Posted August 28, 2010 found i have no pcm connection! going to redo all power and grounds... heres the better news, went and borrowed a VST this afternoon had some fun checking my cars out Link to comment Share on other sites More sharing options...
michael-s70 Posted August 29, 2010 Author Report Share Posted August 29, 2010 wiring harness in mulitple wiring problems with ground and power.... replaced it and started right up. thanks for the help Link to comment Share on other sites More sharing options...
