thewhiteguy1 Posted August 27, 2010 Report Share Posted August 27, 2010 soooo I just put a new rad in and i check out my coolant this morning and i see this. after talking to John he says it's either one of three things: headgasket, turbo, or rad. rad is brand new from fcp, turbo still seems okay no smoke coming from it and still spools good, and my engine has not overheated even with the 90+ degree weather so idk about the hg. and ideas of anything else it could be or if it's one of those three?! thanks. Link to comment Share on other sites More sharing options...
Gilhuly Posted August 27, 2010 Report Share Posted August 27, 2010 do a compression test? That looks like a ton of oil in there. Makes me think that the radiator failed. Did that come on all at once? Link to comment Share on other sites More sharing options...
lengendsecko87 Posted August 27, 2010 Report Share Posted August 27, 2010 I think someone put chocolate in your radiator. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted August 27, 2010 Author Report Share Posted August 27, 2010 do a compression test? That looks like a ton of oil in there. Makes me think that the radiator failed. Did that come on all at once? Yeah I was hoping It wouldn't be that cause it was a brand new radiator. will try and do a compression test this weekend Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted August 27, 2010 Report Share Posted August 27, 2010 It is too much.....probably the radiator.you can also remove the oil cooler's lines from the radiator and pressurize the cooling system,to see if it show something. Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 27, 2010 Report Share Posted August 27, 2010 Dang, what are the chances that you got a bad rad from FCP? Also make sure you get a new coolant expansion tank while you are at it.... oh and a new green cap :) Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted August 27, 2010 Author Report Share Posted August 27, 2010 Dang, what are the chances that you got a bad rad from FCP? Also make sure you get a new coolant expansion tank while you are at it.... oh and a new green cap Dave you love those green caps. Well it's an oem like nissens radiator. I was reading online yhey were like a 1 in 5 you would get a bad one Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 27, 2010 Report Share Posted August 27, 2010 Dave you love those green caps. Well it's an oem like nissens radiator. I was reading online yhey were like a 1 in 5 you would get a bad one Dang that high! Get a new one ASAP and flush that bitch twice! Link to comment Share on other sites More sharing options...
Mesoam Posted August 27, 2010 Report Share Posted August 27, 2010 you sure thats oil and not trans fluid? I'm going with bad rad on this one Link to comment Share on other sites More sharing options...
Fitzy Posted August 27, 2010 Report Share Posted August 27, 2010 Dang, what are the chances that you got a bad rad from FCP? It's happened to me. Also had one go bad and do the same thing. Link to comment Share on other sites More sharing options...
boxpin Posted August 27, 2010 Report Share Posted August 27, 2010 How does your Transmission or engine oil look? Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 30, 2010 Report Share Posted August 30, 2010 Any update? What were the compression numbers? Link to comment Share on other sites More sharing options...
