jbuck Posted December 18, 2004 Report Share Posted December 18, 2004 What is the fuel pressure at the fuel rail supposed to be on my car? I had it tested last night and it was 56. That seems really high. It was tested on high-end equipment, so I believe the results.What could cause this? Could this contribute to my consistent fuel in oil problem? FPR? Thanks is advance. Link to comment Share on other sites More sharing options...
Bay13 Posted December 18, 2004 Report Share Posted December 18, 2004 Ther fuel pressure should be 375 to 395Kpa (54-57Psi) Link to comment Share on other sites More sharing options...
jbuck Posted December 18, 2004 Author Report Share Posted December 18, 2004 Ther fuel pressure should be 375 to 395Kpa (54-57Psi)←Bay 13, thank you. So since all the info I could find on V70s tells me the pressure should be lower, this must be another "V70R" issue. Given the info from your handy Fuel System Specs in the Maintenance section I must have the higher pressure injectors "0 280 150 785". Needed to feed the turbo I imagine. Thanks again. Link to comment Share on other sites More sharing options...
Bay13 Posted December 18, 2004 Report Share Posted December 18, 2004 The key is that you have a 1999. I looked it up on VADIS for you just to be sure, Some are lower and some of the new ones are even higher. Link to comment Share on other sites More sharing options...
MrWinkey Posted December 18, 2004 Report Share Posted December 18, 2004 Wish I had VADIS access.... ...not spendin the 7500 /year to have it though <_< Link to comment Share on other sites More sharing options...
