jbuck Posted December 20, 2004 Report Share Posted December 20, 2004 I'm removing my fuel rail with injectors to see if any of them are leaking. After removing the two bolts, I've wiggled and wiggled but the injectors won't come loose. Anyone have any suggestions? Would it make more sense to wiggle or pull straight out? I have some clamps that I could use to simultaneously "pull" the rail straight out from both sides.Do I need an injector seal kit before removing? Can't find one for '99. I was going to remove the remove the fuel rail with all injectors attached, pressurise the system and see if any of them are dripping. Dealer was going to charge over $100 for the same procedure so I thought I'd try it myself. Thanks in advance. Link to comment Share on other sites More sharing options...
DEWFPO Posted December 20, 2004 Report Share Posted December 20, 2004 They can be tight, I wiggle the fuel rail from side to side slighty(not to much) but evenly while applying more pull back pressure. It will 'pop' out so be careful.DEWFPO Link to comment Share on other sites More sharing options...
WhiteT5 Posted December 21, 2004 Report Share Posted December 21, 2004 Be VERY careful when doing this, as the heads of the injectors are usually brittle from heat and crack VERY easily. Learn from my mistake. I'm glad I have extras laying around. Link to comment Share on other sites More sharing options...
Mesoam Posted December 21, 2004 Report Share Posted December 21, 2004 you need new injector o-rings for the re-install. I found wiggling front to back then side to side helps, start from one outside edge then the other then the middle Link to comment Share on other sites More sharing options...
MrWinkey Posted December 21, 2004 Report Share Posted December 21, 2004 Have you disconnected your fuel line that is strapped down as well ..but the can be tight ..try some pure silicone spray around the bottom while wiggling them Link to comment Share on other sites More sharing options...
