yoked Posted September 21, 2010 Report Share Posted September 21, 2010 Replaced the clutch and had gearbox apart to replace seals and slave. I slapped the gearbox & bell housing back together & reinstalled back on to the engine, reconnected everything back together (wires, mounts etc...). Bled the clutch (forever) and when I finally fired it up the shifter didnt feel right. I tried to put in gear, every gear and the gears did not engage. There's no grinding, no movement of the car , no reverse lights nothing. Someone said my cables were backwards. This is not the case. What did I do wrong? PLEASE advise. Thanks... Link to comment Share on other sites More sharing options...
TxS70 Posted September 21, 2010 Report Share Posted September 21, 2010 check the cables again. If you go to put it in first, does it go where it should? If it does, and it doesnt move when you let the clutch out, thats a whole other story. Link to comment Share on other sites More sharing options...
yoked Posted September 21, 2010 Author Report Share Posted September 21, 2010 It does actually seem to go into first a little stiff but yes it does. In fact thats the only spot the shifter seems to somewhat feels normal. Link to comment Share on other sites More sharing options...
MrWinkey Posted September 21, 2010 Report Share Posted September 21, 2010 Back bleed the clutch hydraulics. Get a metal trigger oil can, fill it with brake fluid,slide some vacuum hose on the tip of the can then onto the bleeder screw, crack the slave bleeder screw and pump brake fluid into it, watch the air push into the master as it fills up. Link to comment Share on other sites More sharing options...
yoked Posted September 22, 2010 Author Report Share Posted September 22, 2010 When I said it went into first I was only talking about the shifter. The car itself does not move the slightest in any any gear And the reverse lights dont work. Link to comment Share on other sites More sharing options...
yoked Posted September 23, 2010 Author Report Share Posted September 23, 2010 HaD the car towed to volvo yesterday they call today and tell me one of the clutch cables is severed and yhe clutch needs to be bled again 660$. so i told them to proceed... sound about right? Link to comment Share on other sites More sharing options...
