trance42 Posted September 25, 2010 Report Share Posted September 25, 2010 VMS SHORT BLOCK about 40k miles Small hotspot on #3 piston. Probably would be a good idea to replace rings and check bearings. 750 + shipping obo The following is from the VMS website: VMS connecting rod and piston set have been custom designed for optimal performance with the rods being .100 longer than stock and 105 grams lighter than the factory rods we believe that this set will handle up to 550hp with the proper tune up. We have worked real hard to develop a custom setup that can be affordable as well as reliable by using an H beam 4340 chrome moly connecting rods and Ross piston we believe that when you purchase our piston and rod set or a complete rotating assembly that you will be buying the best that is available. Link to comment Share on other sites More sharing options...
Mesoam Posted September 25, 2010 Report Share Posted September 25, 2010 might be worth mentioning what rods/pistons are in it Link to comment Share on other sites More sharing options...
BlackT5 Posted September 25, 2010 Report Share Posted September 25, 2010 VMS short block = Ross pistons & Eagle H-beam rods. http://www.volvomotorsports.com/catalog2/product_info.php?cPath=24&products_id=71 Link to comment Share on other sites More sharing options...
trance42 Posted September 25, 2010 Author Report Share Posted September 25, 2010 might be worth mentioning what rods/pistons are in it Good Thinking Thanks Link to comment Share on other sites More sharing options...
trance42 Posted September 25, 2010 Author Report Share Posted September 25, 2010 VMS short block = Ross pistons & Eagle H-beam rods. http://www.volvomotorsports.com/catalog2/product_info.php?cPath=24&products_id=71 Thanks Black T5 Link to comment Share on other sites More sharing options...
magicaljake Posted September 25, 2010 Report Share Posted September 25, 2010 where are you located? Link to comment Share on other sites More sharing options...
trance42 Posted September 25, 2010 Author Report Share Posted September 25, 2010 where are you located? Annapolis MD Link to comment Share on other sites More sharing options...
TRACStar Posted September 26, 2010 Report Share Posted September 26, 2010 Do you have any shots of the hotspot on cyl 3? Is it something to worry about or more cosmetic? Link to comment Share on other sites More sharing options...
mkb Posted September 26, 2010 Report Share Posted September 26, 2010 What's the history on this motor? Did you buy it new? Link to comment Share on other sites More sharing options...
damitzmike Posted September 26, 2010 Report Share Posted September 26, 2010 from what i hear about VMS that might just be a stock motor claiming to be built. Link to comment Share on other sites More sharing options...
TRACStar Posted September 26, 2010 Report Share Posted September 26, 2010 who's the -1 fairy in here? :lol: Link to comment Share on other sites More sharing options...
trance42 Posted September 26, 2010 Author Report Share Posted September 26, 2010 from what i hear about VMS that might just be a stock motor claiming to be built. You cant believe everything you hear. You should keep you stupidity to yourself. Do you have any shots of the hotspot on cyl 3? Is it something to worry about or more cosmetic? Link to comment Share on other sites More sharing options...
TRACStar Posted September 26, 2010 Report Share Posted September 26, 2010 :o Does it make it all the way through or is it still sealed? Its hard to tell from that angle. Link to comment Share on other sites More sharing options...
trance42 Posted September 26, 2010 Author Report Share Posted September 26, 2010 What's the history on this motor? Did you buy it new? I bought it from mike in Chicago. He had it for a very short time and was fed up with the fact that he kept blowing differentials. At the time, you couldn't get a hold of a stronger differential. There was no demand for them. He parted out his car and I bought his VMS motor, 30/35r turbo, clutch, and a bunch of other goodies for around 10k$. I haven't been disappointed. The only problem I have ever had form the VMS motor was in the head. Valve seals went bad. I changed them and I had no other issues. Below is a link to pictures of the motor that VMS took during the build. http://www.volvomotorsports.com/gallery/thumbnails.php?album=9 Link to comment Share on other sites More sharing options...
trance42 Posted September 26, 2010 Author Report Share Posted September 26, 2010 Does it make it all the way through or is it still sealed? Its hard to tell from that angle. No it doesn't go all the way through. The motor runs fine with it. Its a very small place in the piston. I called VMS to inquire about getting a new piston at one time and terry(not sure if that is his name) said i shouldn't worry about it. Its near the wall so there is a good amount of metal underneath. Link to comment Share on other sites More sharing options...
