Matty Moo Posted October 1, 2010 Author Report Share Posted October 1, 2010 This is an ENGINE REMOVAL DIY, but the Flex Plate info is in Step #63: http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=28973 That's actually the one I read before I started tearing into this. That guy put a ton of time into documenting that. Link to comment Share on other sites More sharing options...
the commissar! Posted October 1, 2010 Report Share Posted October 1, 2010 Last one I did didn't want to come out with a pic or screw driver so I did this...worked like a charm! This is what my mechanic did: 1. Drill 2 pilot holes in the seal flange, taking care not to damage the sealing surfaces (crankshaft or outer surface). 2. Insert 2 sheet metal screws then pull the seal. 3. Keep the old seal for driving in NEW seal. I posted the pic recently but here it goes. Info from Honda CRV but the idea is the same. http://crxcommunity....topic.php?t=226 Link to comment Share on other sites More sharing options...
volvoskiah Posted October 1, 2010 Report Share Posted October 1, 2010 make sure to lubricate the new one with oil. I just tapped one side in a little and the other side popped out. Used the old one to put in the new one! Link to comment Share on other sites More sharing options...
AverageVolvo Posted October 1, 2010 Report Share Posted October 1, 2010 make sure to lubricate the new one with oil. I just tapped one side in a little and the other side popped out. Used the old one to put in the new one! Um NO> Great way to let it seep. Perhaps a tad in the inner against the rotating portion. But it's not needed, I have done quite a few never had a leak, longest one is at 25k so far. Link to comment Share on other sites More sharing options...
Cal3thousand Posted October 1, 2010 Report Share Posted October 1, 2010 Yeah, I read up on that. I'm glad I did since I've never touched a transmission before. So, I drain the TC, then put it back in and it will get filled back up when it's in? I wish I had read up before installing the damn TC onto the flywheel first ... ... oh well... here's to more experience as for the TC, I've heard to fill it with Qt of fluid before putting in... anyone confirm? Link to comment Share on other sites More sharing options...
volvoskiah Posted October 1, 2010 Report Share Posted October 1, 2010 Um NO> Great way to let it seep. Perhaps a tad in the inner against the rotating portion. But it's not needed, I have done quite a few never had a leak, longest one is at 25k so far. Too bad you are wrong sir. A great way to let it seep would be to not lubricate it. Your lucky that you haven't had a leak. You always lubricate seals before you put them in to make a complete seal all the way around. Link to comment Share on other sites More sharing options...
