Rex Posted October 6, 2010 Report Share Posted October 6, 2010 Hi All, Have the chance of a rear pair of 2006 S60R rear four pots to finish off my brake upgrades. Has anyone fitted these to a 1998 V70R AWD? Do they bolt straight on or are brackets required? They're fitted in an identical position, i.e they're to the front of the car (or the right) when looking at the rear wheel as on mine.... Regards, Rex Link to comment Share on other sites More sharing options...
flyfishing3 Posted October 6, 2010 Report Share Posted October 6, 2010 going to need brackets. Link to comment Share on other sites More sharing options...
Rex Posted October 6, 2010 Author Report Share Posted October 6, 2010 As long as it can be done..... Thanks for the reply. Rex Link to comment Share on other sites More sharing options...
Chilled man Posted October 6, 2010 Report Share Posted October 6, 2010 you would be better off with the porsche calipers then the S60R will be easier to fit Link to comment Share on other sites More sharing options...
Rex Posted October 6, 2010 Author Report Share Posted October 6, 2010 you would be better off with the porsche calipers then the S60R will be easier to fit On the rear? Link to comment Share on other sites More sharing options...
flyfishing3 Posted October 6, 2010 Report Share Posted October 6, 2010 http://volvospeed.com/vs_forum/index.php/topic/135256-rear-bbk-installed/page__p__1808599#entry1808599 ;) Link to comment Share on other sites More sharing options...
Rex Posted October 6, 2010 Author Report Share Posted October 6, 2010 http://volvospeed.com/vs_forum/index.php/topic/135256-rear-bbk-installed/page__p__1808599#entry1808599 Heh, I had a set for the front but decided to go with the AP's and subsequently listed the Porsche calipers on eBay. Bummer. Are people using that setup using brake bias adjusters? Link to comment Share on other sites More sharing options...
Rex Posted October 7, 2010 Author Report Share Posted October 7, 2010 ? Link to comment Share on other sites More sharing options...
Zappo Posted October 7, 2010 Report Share Posted October 7, 2010 Heh, I had a set for the front but decided to go with the AP's and subsequently listed the Porsche calipers on eBay. Bummer. Are people using that setup using brake bias adjusters? I have the Porsche brakes on front, S60R on the rear. No bias adjustment needed. Link to comment Share on other sites More sharing options...
Emiel Posted October 7, 2010 Report Share Posted October 7, 2010 Heh, I had a set for the front but decided to go with the AP's and subsequently listed the Porsche calipers on eBay. Bummer. Are people using that setup using brake bias adjusters? I had the Porsche set at the front and S60R Brembo's at the rear and needed a brake bias adjuster, but then I sold the 850.. The rear locked up pretty easy on my car. Link to comment Share on other sites More sharing options...
matt b Posted October 7, 2010 Report Share Posted October 7, 2010 Rex: V70, non ? Je peux t'en envoyer des US, je l'ai fait avec d'autres personnes ici. Mais en effet, il faut des petites modifs. PM moi si tu as des questions a ce sujet, c'est faisable. Link to comment Share on other sites More sharing options...
Rex Posted January 12, 2011 Author Report Share Posted January 12, 2011 Hi all, Just a quickie - the S60R discs are now on the shelf I just need the calipers! Some Porsche fronts have come up but off a 997, not a 996. Can anyone tell me if that's going to pose a problem? Regards, R Link to comment Share on other sites More sharing options...
Che'_Moderator Posted January 12, 2011 Report Share Posted January 12, 2011 I think the newer 2s and 4s brakes will work. The older ones will not. Link to comment Share on other sites More sharing options...
Rex Posted January 12, 2011 Author Report Share Posted January 12, 2011 Hi Che, Do you mean newer 997's? Or pre 996? :-o Link to comment Share on other sites More sharing options...
