blazen244 Posted October 18, 2010 Report Share Posted October 18, 2010 Need help from the guys that have 18" rims on their T-5's. What size tires did you use? Link to comment Share on other sites More sharing options...
850T5M Posted October 18, 2010 Report Share Posted October 18, 2010 Wrong Forum, and I have no clue lol Link to comment Share on other sites More sharing options...
blazen244 Posted October 18, 2010 Author Report Share Posted October 18, 2010 where should it be? Link to comment Share on other sites More sharing options...
(n)A-GAME Posted October 18, 2010 Report Share Posted October 18, 2010 225/40/18 rubs on S70's. You'd probably want a 215/40/18 if the roads are bad by you, or 215/35/18 if the roads are good. Link to comment Share on other sites More sharing options...
blazen244 Posted October 18, 2010 Author Report Share Posted October 18, 2010 225/40/18 rubs on S70's. You'd probably want a 215/40/18 if the roads are bad by you, or 215/35/18 if the roads are good. Thanks sounds like I'd be better off going with 17" rims. Link to comment Share on other sites More sharing options...
Wagoneer855 Posted October 18, 2010 Report Share Posted October 18, 2010 225/40/18 rubs on S70's. You'd probably want a 215/40/18 if the roads are bad by you, or 215/35/18 if the roads are good. 215/35/18s would be brutal and the diameter is too small. Go with 225/35 if you want the wide tire or 215/40 if you don't want any chances of rubbing. Link to comment Share on other sites More sharing options...
andyb5 Posted October 18, 2010 Report Share Posted October 18, 2010 If you want to compare the diameters of different tire sizes, use this calculator: http://www.miata.net/garage/tirecalc.html Link to comment Share on other sites More sharing options...
laird Posted October 18, 2010 Report Share Posted October 18, 2010 You really need to see individual tire specs because one manufacturers 225/35 may be very different from another. Tire Rack has a pretty good reference. Link to comment Share on other sites More sharing options...
aggarcia Posted October 18, 2010 Report Share Posted October 18, 2010 I have 18x8 on my 850R and run 215/40/18. No rubbing under normal driving, but stock height. I am planning to lower the car next month. AG Link to comment Share on other sites More sharing options...
Volvowith18psi Posted October 18, 2010 Report Share Posted October 18, 2010 225/40's I dont rub under normal driving and light turns afaik. Trying to park and make U turns is a totally different animal (IPD Springs +18x8) Link to comment Share on other sites More sharing options...
OzzieOzzieOzzieOiOiOi Posted October 19, 2010 Report Share Posted October 19, 2010 I've got 18 x 8 and 215/40 and plenty of rubbing- esp on drivers side. I think my T5R is factory lowered though. Next time I will be going for 225/35 as I think the increased rolling diameter has caused most of the rubbing- not the tyre width. Link to comment Share on other sites More sharing options...
BurgerBob Posted October 19, 2010 Report Share Posted October 19, 2010 285/75 Link to comment Share on other sites More sharing options...
s_moneh Posted October 20, 2010 Report Share Posted October 20, 2010 ^^^^ LOL is there any successful 235/35/r18 or 235/40/r18 runners here? i wan to run 235'sor more like i would need too... Link to comment Share on other sites More sharing options...
irollturbo Posted October 20, 2010 Report Share Posted October 20, 2010 225/40's I dont rub under normal driving and light turns afaik. Trying to park and make U turns is a totally different animal (IPD Springs +18x8) 225/40s on 18x8 pegs rubbed like crazy on my S70 with TME springs. The car was not drivable with a passenger in the back. I ended up rolling the rear fenders and using 5mm spacers. Now things are pretty good. It will only rub in front on full lock and there is a minor inner rub in rear when turing onto a ramp. Link to comment Share on other sites More sharing options...
iBoost Posted October 20, 2010 Report Share Posted October 20, 2010 ^^^^ LOL is there any successful 235/35/r18 or 235/40/r18 runners here? i wan to run 235's or more like i would need too... I run 235/40/17 on my 850 front and back...they rub quite a bit but only on turning and hard cornering Link to comment Share on other sites More sharing options...
